Estimate on a Seat Repair-Cincinnati Tri State
08-13-2015, 09:38 AM | #1 |
10
Rep 44
I have a seat Crack on the driver side.
I have a hard time getting In and Out of the car (328 I) and me putting too much weight on the left panel is what caused the crack i believe. What do you guys think is a decent estimate and do you have any suggestions in the Cincinnati Tri-state Area. I checked with Fisher Griffin and was told the minimum would be 350. |
08-13-2015, 09:56 AM | #3 |
18018
Rep 9,378
^ either way, once you get it fixed (can't help with estimate there) you need to put conditioning the seats into your normal car care routine.
All you can really expect to have done, and yes you will see it, is to have the small piece from the top stich to where your pen is replaced. |
08-13-2015, 10:02 AM | #5 | |
10
Rep 44
Thanks for your input. |
08-13-2015, 10:49 AM | #6 |
18018
Rep 9,378
Mine was black 'ette, but the section that failed was the first small side panel on the top of the driver's seat. I don't think we paid more than $100 at a local auto upholstery shop. I could see the new color for a while, but it became FAR less noticeable than the cracked white the way it was before we repaired it.
08-13-2015, 04:24 PM | #7 |
General
17309
Rep 18,733
I can't tell if that is a base seat or a sport seat, but it doesn't matter much. BMW sells the complete sensatec seat cover as a repair part for about $300 (realOEM has it a $269). I rebuilt my driver's seat because I had a similar problem with the torso section. I replaced the seat foam while I was at it. I had an upholsterer do the work, but on my E30 I did the recovering myself. Not a hard DIY. The trick is to warm the seat cover with a hair dryer to soften the vinyl up to make it easier to stretch over the frame. I'd get the new foam too, since it is no extra effort to replace it.
08-14-2015, 12:09 PM | #8 | |
31
Rep 228
08-14-2015, 09:30 PM | #9 | |
General
17309
Rep 18,733
