TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > E92 19x10 et25-30????
      08-12-2015, 02:54 PM   #1
'V'
43
Drives: ~Carbon black F36
Trying to figure out what I can get away with for my wheels on the rear.
19x10 offset can be between 25 and 30
Thoughts?
I have rolled arches already and off the top of my head will be running a 265 tyre
      08-12-2015, 03:07 PM   #2
AWBimmer
AWBimmer's Avatar
344
Drives: E92 335D Pre-LCI | E63 M6 V10
19x10et 24 is very doable on rear. et30, even more so.
Esp if you have rolled arches. But note, I had a 245/35 tyre. Even a 255/30 will be okay but cannot vouch for 265.
255/30 won't be that much worse off buddy. My style 95 is 10j et24 FYI.
BMW E92 335D | Lower Klasse
IG: @that.m6
      08-12-2015, 03:24 PM   #3
'V'
43
Cool.
Have to stick with a 265 for now tho, so would like it to fit with this size tyre.
Also to note, I haven't had any camber etc changed so that's also worth adding to the mix to get this to work. Again tho, would like to stick with how it is from standard but adding a little -Ve wouldn't be out of the question - just not loads!
      08-13-2015, 03:53 AM   #4
AWBimmer
AWBimmer's Avatar
344
Andy,
Not sure that 265 will fit without camber work. You'll only need it adjusted a tad notch, nothing major. Worth doing IMO.
IG: @that.m6
      08-13-2015, 05:39 AM   #5
'V'
43
Thanks Sam, Def. Something I'll look into and may be what has to be done anyway.
Was running 19x10 et25 on the rear previously which rubbed on hard turns (only on the right tho) and big bumps - that was with SE suspension tho.
If I can get away with sticking with et25 I will (I like the poke) if not I'll up it a little to 30. The extra 5mm will (hopefully) make a difference.
Worst case is I have to ditch my tyres and buy 255 but if I don't have to until I need new ones then perfect.
Need to figure out a better offset for the front too on a 19x8.5
      08-13-2015, 06:00 AM   #6
Digitalize
Photographer
Digitalize's Avatar
412
Drives: 320D
Use the website willitfit and work out what spacer you can run on your current wheel setup and add that to the ET.
      08-13-2015, 06:13 AM   #7
'V'
43
Cheers digi I'll have a look
      08-13-2015, 06:27 AM   #8
AWBimmer
AWBimmer's Avatar
344
I want to downsize my tyres so might sell my 255/30/19 Goodyear Assymetric2 Eagle F1, 5/6mm tread.
If of interest dude let me know
IG: @that.m6
      08-13-2015, 08:41 AM   #9
'V'
43
Will do 👍
      08-23-2015, 03:09 PM   #10
JP.Williams
JP.Williams's Avatar
16
Drives: E93 335i
i have ET24 10J on a 265 30 and you will need alot of camber work yes. it would of been easier to drop a tyre size but i was being stubborn. i still need to finish the final setup on the camber angle but i know its around -3 -3.5 maybe more.
LeMans Blue E93 335i | Koni Yellow | H&R Springs | 9/10J Style 92s | MHD | BMS DCI | VRSF Downpipes | ML Inlets | ML Stage 2 Hybrid Turbos | Retrofit CIC
      08-26-2015, 03:07 AM   #11
'V'
43
Ended up going with et30.
Will still need some adjustment on the 265 tyre but I think it'll work without rubbing - time will tell.
Having my coilivers fitted in the next couple of weeks hopefully so I'll report back with any issues.
Fingers crossed it works out perfect! - yeah right!!! Lol!
      08-26-2015, 03:44 PM   #12
gaza01
gaza01's Avatar
105
Drives: E92 335i
Et30 was the better choice imo
