E90 330i hard to start when hot
08-11-2015, 10:49 PM | #1 |
Rep 104
Hello,
I'm in need of help diagnosing the problem with my '06 e90 330i warm/hot start. Awesome helpers in this forum has made this forum so awesome. And thank you all for your contributions. As the title says I'm having issues with hot/warm start. Cold start fires right up. But when it is hot/warm after the engine reaches normal temperature and park it for more than an hour or longer it takes 2-3 cranks to start the engine. So, far I have replaced coolant temp sensor, engine oil/coolant temp sensor, fuel rail(found pressure leaking from shrader valve), reman. injectors and the problem is still there. Any suggestions or solutions would be highly appreciated. Thank you all |
08-11-2015, 11:12 PM | #3 | |
Rep 104
Since it fires right up during cold start, I didn't suspect the battery. Thank you for the response. |
08-12-2015, 12:47 AM | #4 |
700
Rep 1,227
Have you done a fuel system pressure check? In my experience most issues starting a motor when hot are fuel related. For example Fuel Pump pressure too low
08-12-2015, 05:58 AM | #5 | |
Rep 104
Thanks |
