08-11-2015, 02:30 PM | #1 |
471
Rep 2,991
Jehnert XE200 Flatline direct fit woofers for sale
I replaced my underseat woofers with a set of Jehnert XE200 Flatline woofers. These are designed as midbass speakers and have a great deal of musicality and sound great. Ideally they'd be used with a trunk mounted subwoofer. They are 4ohm and therefore you should run an amp with them - some people have run the stock amp with them and have been ok but you're working with a much lower impedance than stock (stock is 7 ohm vs the Jehnerts at 4 ohm) which will make the amp work harder and the stock amp is an expensive piece to replace. I have the Bimmertech amp and DSP which is awesome and the Jehnerts are a great set of speakers at doing what they are supposed to do - just don't expect earth shattering rumble with them, expect a much more musical thump and slap. Like I said, my original plan was to use them with a trunk sub and that would really be the best plan ideally. I paid $459 shipped, with the adapter rings that space them out more. I made simple plug and play wiring harnesses so you don't have to cut the factory harnesses. Includes replacement screws too, since you'll need longer ones with the adapter rings. They are basically brand new, installed and swapped for the Earthquakes after about 30 minutes of play time and a couple days of being installed. Worked great in my F82 and will fit many other BMWs. (drops right into the F30/F32/etc) Your's for $400 shipped. (PRICE DROP TO $325 shipped in the CONUS) SOLD!!!!!!!!!!!!!!!!!!! Last edited by kitw; 08-22-2015 at 12:59 PM.. |
