cleaning the MAP sensor
08-11-2015, 11:37 AM | #1 |
15
Rep 157
Read about this in an old thread and thought it might help with my code. Any experiences or thoughts about cleaning with swtich cleaner or electrical parts cleaner?
08-11-2015, 11:47 AM | #2 |
530
Rep 2,083
I just cleaned mine this morning. I used MAF sensor cleaner. Its similar to brake cleaner (high pressure aerosol can) but it's supposed to be safe for MAF sensors, so I figured it would be okay for the TMAP sensor. Haven't installed it to make sure it worked.
I believe there are 2 TMAP sensors, in the chargepipe and in the intake manifold. Mine in the intake was particularly dirty.
2013 135is DCT Carbon Black Metallic |
08-11-2015, 12:10 PM | #3 |
15
Rep 157
I heard switch cleaner works good. Im getting the code p119a after i cleaned out my intake but im not sure if its safe to drive with it like that. It drives well i just hate seeing that ses light
08-11-2015, 01:46 PM | #4 |
75
Rep 630
Drives: '09 335 E93 6MT
TMAP measures pressure. I dont know how cleaning it would help, especially that it will just get dirty again with all the oil in the air.
08-11-2015, 01:54 PM | #5 |
15
Rep 157
Ive been reading up and i guess there are two on my car n54. One at the intake and one on charge pipe please correct me if im wrong
08-11-2015, 02:01 PM | #6 | |
530
Rep 2,083
It also measures temperature, so oil/grease on the sensor could affect its accuracy and response time.
08-11-2015, 03:42 PM | #7 |
15
Rep 157
Thank you for the response. I picked up some electric parts cleaner and im going to clean the connections tomorrow morning. Im thinking maybe when i was cleaning the intakes some gunk got on the connector itself and thats whats causing the code. Will update tomorrow. Is it perfectly fine to spray the connector while the battery is hooked up or should i unplug?
