bmw 328xi 2007 cat converter glowing.
08-10-2015, 08:24 PM | #1 |
60
Rep 309
Hi there i recently just replaced my cats due to the old ones going bad. i had them replaced but now when you start the car the catalytic converters are glowing red. Any ideas whats wrong? all spark plugs have been replaced
08-12-2015, 10:20 PM | #2 |
Gateropode
329
Rep 2,848
You are running lean, either a vacuum leak post-O2/MAF on the intake, or a low pressure on the fuel rail. Should have shadow codes in the computer in both cases regarding incorrect mixture and timing corrections.
08-13-2015, 07:29 AM | #3 |
266
Rep 952
I second the lean or wrong fuel mix condition. You have un-burnt fuel making it's way into the exhaust and it is getting burned in the cats, creating heat and turning them red.
This is also possibly the reason the previous set of cats went bad. Get it checked out, or you'll quickly be in the market for a 3rd set of cats.
bone stock
08-13-2015, 07:55 AM | #4 | |
193
Rep 666
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
08-13-2015, 08:13 AM | #5 |
266
Rep 952
He didn't mention the idle being too high which is typically a symptom of an overly rich condition. It's hard to add extra fuel to the cylinder without increasing the RPMs.
However, this is still a possibility, so I think the best description is wrong mix. In a really lean condition, the cylinder will not ignite at all, which is a mis-fire. All the fuel is then dumped into the exhaust.
bone stock
