Quaife - Limited Slip Differential, 335i
08-07-2015, 11:41 AM | #1 |
Rep 83
Can someone please point me to a reputable LSD seller in the US for my 335i ? I believe I have the welded diff since I have a 2013 so I am not able to find any good US stores thus far. Thanks.
08-07-2015, 12:36 PM | #2 |
247
Rep 416
I've never used this vendor, but it looks like they carry it.
http://www.evasivemotorsports.com/mm...k2rxoCj7Xw_wcB |
08-07-2015, 12:38 PM | #3 |
Rep 97
Why not keep the welded? Wouldn't it do the same job? I used to have a s14 with a welded and it was loads of fun. I have xDrive now for Chicago winters, I miss the RWD
08-07-2015, 01:34 PM | #4 | |
453
Rep 2,973
They are a sponsor and have a solution for the welded ring gear. http://www.e90post.com/forums/showth...&highlight=LSD
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
08-08-2015, 12:19 PM | #5 | |
Nomore
149
Rep 793
He does not have a welded or locked diff like your thinking of. He has an open diff with a welded ring gear as oposed to earlier build e90's with a bolted ring gear that ca be unbolted and bolted to a new LSD unit and reinstalled. |
08-08-2015, 12:55 PM | #6 |
659
Rep 1,525
Forget Quaife and go with MFactory. If you time it right you can get the complete pumpkin to swap out, the bushings and install done for under 2 grand. If available, consider the higher numerical gear ratio. Be prepared for a slight thunk though, as it may be present.
08-09-2015, 12:04 PM | #7 |
1903
Rep 6,968
