M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Regional Forums > UK
      08-07-2015, 12:24 AM   #1
jamier27
15
Drives: F10 M5
Running in
What's peoples way of running the M5 in?
I've read debates for most other cars I've looked at over the years and they say drive hard from day one or you'll get a "slow" one. But that is for lower performance cars, I'd imagine this one takes a bit more care ??
      08-07-2015, 03:15 AM   #2
RichDM5
Drives: 2014 F10 M5
I went by the book, took my time and drove normally. Any chance I could to do a longer trip I would load the miles on.
2014 F10 M5
2012 Aston Martin Vantage
2010 Audi S5
      08-07-2015, 04:45 AM   #3
jamier27
15
Drives: F10 M5
I remember a car I had years ago and was to run it in short journeys so more revs and gears were used as allowed to 4x300 mile journeys where the car is ticking over 90% of the time....
Also don't go above 106mph??
      08-07-2015, 05:53 AM   #4
skansa
12
Drives: Datsun Sunny
from what i read, and what i intend to follow, is first 40-50 miles vary revs and do engine braking. this helps bed the pistons in. from that point then follow the manual.
      08-11-2015, 02:04 AM   #5
rjberry
rjberry's Avatar
412
Drives: F31 340i Ruby Red II
For me, I waited for the engine to get some temperature on the gauge and then drove it as I normally would.
I picked mine up in December though so not the best time of year to try to put too much power down.
I think as long as you try not to keep the revs constant for too long and try to avoid the red line you'll be fine.
Drive it and enjoy it
      08-11-2015, 02:55 AM   #6
jamier27
15
Drives: F10 M5
Thanks, so there's no physical limit on revs or speed set before running in. Read a debate that the power is dulled down until the running in service is completed... Can't see that?!
      08-11-2015, 04:17 AM   #7
skansa
12
look at previous threads! there is RPM and MPH restriction. 5.5k and 114mph of the top of my head, but check.
      08-11-2015, 04:38 AM   #8
rjberry
rjberry's Avatar
412
Nothing is physically limited, it's more the manual telling you what it recommends you to do. I may have given it a bit more than the stated parameters once or twice
The running in service is just a change of fluids as far as I was told. Nothing is switched to turn on more power but the drive home should be via the scenic route just to make sure
m5post
