question about my thermostat! please advice!
08-05-2015, 03:50 PM | #1 |
15
Rep 157
Got my intake cleaned out and have my ofhg all put back nice and snug now i want to tackle the thermostat because of code p0128. I took my intercooler out and i need to know do i need to take the waterpump off to replace the thermostat. The previous owner changed the waterpump already so i dont want to mess with it. Please tell me if any of you have changed the thermostat without removing waterpump. Thanks!
08-05-2015, 03:57 PM | #2 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
You have to remove the waterpump in order to take the thermostat out. And I'm pretty sure the FMIC doesn't need to come out.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
08-05-2015, 04:00 PM | #3 |
15
Rep 157
08-05-2015, 04:11 PM | #4 |
58
Rep 665
Don't believe that's correct -- the thermostat can be removed without removing the water pump but since most of the hoses go to the thermostat and not the water pump it may actually be easier from an access perspective just to remove both as a single unit. There are a ton of DIY's and videos on how to do it. The DIY on Pelican Parts is good if you just want to remove the thermostat and leave the water pump in place.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
08-05-2015, 04:17 PM | #5 | |
15
Rep 157
08-05-2015, 04:53 PM | #6 |
58
Rep 665
I did both at the same time so I can't say for sure how much harder it is, but the water pump only has two hoses and one of them is the "U" shaped hose that goes to the thermostat. Most people recommend replacing that hose at the same time and if you're going that far, you might as well just remove the water pump too. Up to you though.
08-05-2015, 05:10 PM | #8 |
15
Rep 157
08-05-2015, 05:11 PM | #9 |
215
Rep 1,818
note that there's two versions of the bolt, depending whether or not your pump has the vibration reduction built into it or not
08-05-2015, 05:48 PM | #10 |
15
Rep 157
Thanks a lot man for your help! If you look at my other post about cleaning the valves i posted a picture of this vacuum line that came loose on the right side of the engine do you have any idea what it could be. Again thank you!
08-05-2015, 09:59 PM | #11 | |
1552
Rep 3,475
08-05-2015, 10:04 PM | #12 |
44
Rep 359
You can do it without removing the water pump.. But you'll have to remove the FMIC and use the space to pull the thermostat from there .. I did it a couple of months ago.. Mine cracked in half after i rplaced it and the water pump a year ago lol.
08-05-2015, 10:12 PM | #13 |
1552
Rep 3,475
So coming in from the front, i.e. removing the fmic and going in through there, you don't need to remove the pump. Coming in from the bottom, i.e. not removing the fmic, you probably need to remove the pump.
