DPF queries
08-03-2015, 07:15 AM | #1 |
Rep 68
DPF queries
afternool all - firstly let me apologise I know these questions have been asked before but every other thread says something different.
Firstly what is an acceptable level of soot to remain in the DPF before it should regen? Using bmwhat app I noticed I had a fault code for particulate filter but nothing yet appeared on the idrive. I could see my DPF contained 43g of soot mass and I managed to force a regen using the app which cleared it down to 1.5g of soot mass. After another 15 miles the soot mass steadily rose to 26g... Why would this be? What exactly are the required parameters for the DPF to regen without manual interventions. Thanks again all. |
08-03-2015, 07:21 AM | #2 |
175
Rep 1,596
DPF regen requires coolant to be over 75c, exhaust gas temp to be over 250c and no major fault codes.
if it really has collected 26g of soot in 15 miles it might indicate some issue with the engine producing far too much smoke, for instance a boost leak. I think the soot is more of a calculated value however, it computes it from the backpressure measured across the filter. |
08-03-2015, 08:22 AM | #3 | |
Rep 68
I believe bmwhat app can also measure boost pressure, what sort of boost would a mapped 330d be running? It's not an overly aggressive map and is around 280bhp I believe. Is there anything else that could cause the soot to build up quicker than normal? |
08-03-2015, 12:08 PM | #5 | |
Rep 68
Am I wrong in thinking any faulty sensors would give an error code? |
