BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > New Wheels - Rubbing
      07-29-2015, 05:52 AM   #1
ArsE92
ArsE92's Avatar
23
Drives: E92 335i SE
Hi All
Earlier this week I had my new set of CM Wheels CSL Style wheels fitted. They look brilliant...
...however, I now have a serious rubbing problem.
These wheels replaced 19" 230 style wheels and I'm using the same tyres; Michelin PS2 225/35/19 up front, and Michelin PSS 255/30/19 at the rear.
The offset of the new wheels are:
19x8.5 ET38
19x9.5 ET27
I've no idea about offsets but I'm assured by CM that these should fit without an issue, and I've no reason to doubt that.
Whenever I go over a bump at speed, or a sharp left-turn, I hear a graunching noise from the off-side rear. This is what has happened to the tyre over the last couple of days, but only on the off-side. The near-side is fine!
Any ideas what the issue may be? Everything was fine on the 230's so it will be a massive coincidence if a spring has suddenly snapped or something. Otherwise, the car seems to handle just fine.
Edit: According to this website, due to the different offset of the 230 wheel, "he outer rim will poke out 12mm more than before". Is that the issue? If so, how come it's only apparent on one side?!
Cheers all
      07-29-2015, 06:06 AM   #2
Phil325i
Phil325i's Avatar
616
Drives: E92 325i MSport Coupe
Rubbing on one side only is not uncommon. I had the same issue. You'll need to get your rear arches rolled - or in your case, just the offside. You may not need much of the lip rolled. If you jack the car up and look at the arch, you should see where it's rubbing. I only needed a short section towards the rear of the arch rolled.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      07-29-2015, 07:03 AM   #3
Aragorn30d
175
Drives: E90 330d
the new wheels are wider, and have a lower offset. Both of these things acts to push the wheel further out.
So you've gone from ET39 on the 230 to ET27, which has pushed the wheel out 12mm, but the new wheel is also half inch wider, meaning it sticks out a quarter inch more as well.
As above, there are tolerances at work and often the rear end isnt perfectly central under the car, so it can catch on one side and not the other.
I would get both rear arches rolled which should sort the issue.
      07-29-2015, 07:14 AM   #4
gaza01
gaza01's Avatar
105
Drives: E92 335i
You are most likely rubbing where the fender meets the bumper. Not great as this area can't be rolled. Could try another tyre brand...michelins are usually quite chunky. Conti5p are slightly slimmer (all for the same size / profile of tyre)
      07-29-2015, 07:33 AM   #5
webby888
Drives: 330D E92
Are these the atomic CSL style wheels they do?
I have them from CM Wheels in the same specs as yours and get no rubbing what so ever even with a full load over bumps.
I have continental tyres on though.
Perhaps there is something in your arch that isn't fully clipped in?
      07-29-2015, 09:05 AM   #6
AWSAWS
AWSAWS's Avatar
283
Drives: E92 GC Turbos, FBO, 335i DCT
Fender rolling time matey. I got rubbing on just the left rear wheel (rear near side) when using 15mm spacers on my car with 255 size wheels and stock alloys.
I've taken the spacers off until I do some rolling myself
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos)
11.74@129mph (GC Turbos)
      07-29-2015, 09:58 AM   #7
BirdsEye
Drives: E92 335D
Me too, same wheels running 255 goodyear eagle F1 tyres and no rubbing here, even when I had stuff in the boot and 2 people sat in the back.
      07-29-2015, 10:10 AM   #8
Aragorn30d
175
Drives: E90 330d
Could even be that your wheel alignment is out slightly on that side?
      07-29-2015, 10:11 AM   #9
AWSAWS
AWSAWS's Avatar
283
You could jack the car up or park on a curb to see where it's likely contacting. Feel inside with your hand.
      07-29-2015, 10:41 AM   #10
Powie
Drives: E92 320d M Sport
I have the same alloys, but 265/30/19 tyres also no rubbing!
      07-29-2015, 11:47 AM   #11
marknjayne
23
Drives: 335d
happened to me,i rolled the arch slightly,problem solved
      09-17-2015, 03:00 PM   #12
ArsE92
ArsE92's Avatar
23
Drives: E92 335i SE
Thanks all for the responses and apologies for the delay!
It has settled down a lot now, doesn't seem to rub as much as it did. Whether that's because it's worn part of the arch away is unclear
When I need new rear tyres I'll probably just go back to Conti's
Cheers
      09-17-2015, 06:59 PM   #13
lolololol
96
Drives: M4 F83
Get the fenders rolled mate - end of story
Engine Mods: VF HEX Stage 2, ER Charge Pipes, VRSF Catless Downpipes, BMS Intakes and PCW Exhaust Mod
Running Gear Mods: HRE Flow Form F01, Yellow Stuff pads.
Cosmetic: Performance Grill, Lip Spoiler, Splitters, Side Skirt Extensions, Diffuser and BMS Tips
      09-18-2015, 04:05 AM   #14
Aragorn30d
175
Drives: E90 330d
its probably bent the lip up a bit by itself, not ideal though as its potentially rubbed the paint off and could cause the arch to rust in future.
I would go get it properly rolled, and then ensure the paint is properly sealed/protected to ensure its not going to rust up.
      09-18-2015, 06:52 AM   #15
singh21
singh21's Avatar
England
81
Drives: BMW M4
How much does it cost to get the fenders rolled?
      09-18-2015, 06:55 AM   #16
imy
84
Drives: M140i
depends where you are,
But generally between £80 - £100 for a pair and £120 - £140 for all four.
I would look to maybe flare them instead to give it a bit of a wider look.
      09-18-2015, 09:37 AM   #17
Digitalize
Photographer
Digitalize's Avatar
412
Drives: 320D
Don't flare them, always looks terrible. Just rolled to keep that nice sharp line.
      09-18-2015, 12:25 PM   #18
imy
84
Drives: M140i
Flares look terrible? Really? Seen some done by arch enemy. Looked good to me. Each to their own i guess.
      09-18-2015, 04:12 PM   #19
ArsE92
ArsE92's Avatar
23
Drives: E92 335i SE
Any recommendations in the North West?
      09-18-2015, 05:14 PM   #20
RajB
RajB's Avatar
448
Drives: E92 335i
Although yes the sizes and offsets have pushed the rims out considerably from the OE ones I would potentially just get the alignment checked first just to be sure it's not an issue. If all good then yes just roll the arches and sorted.
E92 335i / M3 Hybrid - The Build
      09-19-2015, 02:18 AM   #21
ArsE92
ArsE92's Avatar
23
Drives: E92 335i SE
Cheers Raj. I had full Hunter alignment weeks before fitting the new wheels
      09-19-2015, 05:32 AM   #22
RajB
RajB's Avatar
448
Drives: E92 335i
Ah ok. Then yup just roll the arches and sorted.
Also the new rims have pushed out a further 18.4mm than the 230's.
