JB4 install - Help
07-25-2015, 02:52 PM | #1 |
10
Rep 187
JB4 install - Help
I installed JB4 this afternoon, bought used off a forum member, and when I start the car I get a engine fault warning - reduced power. Its a yellow engine icon. I have followed the instructions for the error, checked and rechecked all the connectors, they are all on fine.. The board is plugged into the harness as well. This happened from the very first start with the JB4 installed
I took the car for a drive, with the map set to 0 and the car is definitely running on reduced power I did use INPA to delete all the error codes, then log the current codes. Does anyone have any suggestions on what it could be? Any help is much appreciated!! Thanks Fez Last edited by Fez335i; 07-25-2015 at 05:29 PM.. |
07-25-2015, 04:27 PM | #2 |
23
Rep 396
Have you triple-checked the connections? I seem to remember one of my power wires had fallen out (the one with the spade connector I think). The JB4 still worked I think but it wasn't quite right.
I had to solder it in the end. |
07-25-2015, 05:32 PM | #3 |
10
Rep 187
Yes I've checked and re-checked the connectors about 5 times..
The two error codes I get are: 3100 boost pressure control, deactivation 2A80 inlet-Vanos variable can control test, input signal |
07-26-2015, 12:59 AM | #4 |
67
Rep 1,431
I'm going to state the obvious but, 99% of the time it is installation error.
Read through the pdf guide and see if you have missed anything. http://burgertuning.com/instructions/JB4PnP.pdf WM |
07-26-2015, 03:42 AM | #5 |
96
Rep 2,204
+1 .....or
Could be a faulty unit ?
Engine Mods: VF HEX Stage 2, ER Charge Pipes, VRSF Catless Downpipes, BMS Intakes and PCW Exhaust Mod
Running Gear Mods: HRE Flow Form F01, Yellow Stuff pads. Cosmetic: Performance Grill, Lip Spoiler, Splitters, Side Skirt Extensions, Diffuser and BMS Tips |
07-26-2015, 03:53 AM | #6 |
13
Rep 244
Hi,
Fez bought the unit from me, had it in my car for about a year didnt have any issues. I did get errors under WOT but new coil packs fixed that, a common Jb4 prob. Other than that i can only thinl the power connector isnt on properly in the green harness, or the leads have slid back slighty when put back into the ecu. I guess you can enter the jb menu ok? Which would show the jb4 being picked up ok |
07-26-2015, 07:03 AM | #8 |
10
Rep 187
Yeah I can enter the JB4 menu with the steering wheel controls, so the unit is being picked up.
I'm going to try taking it all out and starting from the beginning again today, fingers crossed that works! |
07-26-2015, 07:05 AM | #9 |
886
Rep 9,097
+1
07-26-2015, 10:29 AM | #10 |
10
Rep 187
All sorted!
I disconnected and reconnected everything.. It was plugged in the right way, so its a puzzle as to why it why it was causing issues.. But glad its working now Did a couple of runs, and to be honest it doesn't feel that much more powerful.. Will have to test it a bit more when its not pouring with rain.. |
07-26-2015, 10:59 AM | #11 | |
76
Rep 1,518
07-26-2015, 11:02 AM | #12 | |
10
Rep 187
To be honest it was pouring with rain and the roads were quite busy... Will go out again tonight and give it another go |
07-26-2015, 11:43 AM | #13 |
283
Rep 2,343
Map 5 will be the best for you mate. If you have the usb cable then do some logs and see how much boost you run.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
07-26-2015, 01:49 PM | #15 |
10
Rep 187
Did a few runs on Map 5 and the car deffo feels much faster now!!
Thanks for the help everyone.. Next up front mount intercooler which I've also bought off a forum member! |
07-26-2015, 01:51 PM | #16 |
886
Rep 9,097
Can you run map 5 on a standard car?
I though with each map, you were given list of mods.
07-26-2015, 02:29 PM | #17 | |
96
Rep 2,204
07-26-2015, 03:25 PM | #18 |
886
Rep 9,097
