07-20-2015, 11:07 AM | #1 |
55
Rep 162
Low Oil Warning
Hi all!
This is my first BMW so please pardon me if I am being ignorant My 235 is about 8 months old and it has a little less than 5K miles on it (I had been down with a bad back for a few months). Anyway, yesterday, I got the "Engine Oil Low - Add 1 quart of oil as soon as possible" message. Is this normal? Is my car burning oil? I have broken it in very carefully and because of my still-healing back, I havent driven it hard either. I have had an Acura TSX and a Honda Accord before and this has never happened on those - they were fine until the next oil change and I never had to add oil (let alone have the light come on) in the 20 plus years I had them. Any advice will be very much appreciated! Thank you! |
07-20-2015, 11:19 AM | #2 |
1904
Rep 5,097
I had to add a quart around 8k kms. Car is now at 11k kms and haven't had to add any since that first time. I'm not qualified to say if it's normal, although my dealer says yes.
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
07-20-2015, 11:22 AM | #3 |
206
Rep 602
Interesting indeed!! I have never had this in my BMW's with several recent new ones. or with 2ffer. It could be:
1. Not filled enough when you got it? Doubt that completely though. BUT I guess it could happen when dealer prepped it. 2. Doubt if sump bolt is not tight...but that could be also. If you have not seen a leak on floor, then that's probably not the culprit. 3. Could be a malfunction in the computer reading things inside, and giving a faulty signal. If that was case, then it would not be good to overfill an already full oil sump. My best counsel is take immediately to dealer, or call them. I would not drive it a long distance a qt. low but if you are close, you would be OK. Add the proper oil and definitely get in touch with them, then log it, with miles and date after contacting them, and watch it carefully. It is definitely unusual. |
07-20-2015, 11:53 AM | #4 |
312
Rep 818
My previous 330i was babied from the get-go from my previous owner and it was fantastic..everything was basically like-new. That said, it was babied so much that he never revved it and it burned 1qt every 1,000 miles.
These cars aren't meant to be babied. Our cars/engines are given their tolerances from the factory so they are said to not need a 'break-in' period. I took it easy the first 400-500 miles and since then I've been driving it how I'd normally drive it. "A redline a day keeps the mechanic away" |
07-20-2015, 12:03 PM | #5 |
1538
Rep 3,332
Turbo motors are more likely to burn oil. Keep an eye on it, hard to say whether it is normal or a problem. Most manufacturers have a tolerance on this where it is still "Acceptable" to "Consume" 1 quart per 1000mi.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
07-20-2015, 01:24 PM | #7 |
55
Rep 162
Thanks guys, I called the dealer and have an appointment for Friday. Am leaving town tomorrow, so I dont plan to drive it till then even though the dealer said a few more miles should not be a problem.
07-20-2015, 01:35 PM | #8 |
450
Rep 845
It's normal. I'm at 16k miles and have had to add oil twice -- once at around 5k miles, and then again at around 12k I think. Don't sweat it.
07-20-2015, 02:30 PM | #10 |
1413
Rep 2,519
Drives: 2011 328i Wagon
Keep in mind - these engines hold nearly *8* quarts of oil. Being a single quart low is insignificant - the car is nice enough to tell you at that point. They hold that much oil to allow the long oil change intervals, not because they somehow need it to provide proper lubrication.
I would concur that a quart in 4-5K on brand new engine is more than acceptable. That is exactly what my 328i did when new, and it would now use about 1/2 quart per 10K miles if it ever went that far in a year. Usually about 1/4 quart low on the display when it gets its annual oil change, which has been about 5K per year for the past several years. Having owned MANY turbo cars over the years, I would expect to add a bit of oil now and again.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
07-20-2015, 02:39 PM | #11 |
310
Rep 886
Well, the fill capacity is ~6.5 liters, so nearly *7* would be more correct.
That being said, there's enough headspace in the crankcase to add 8 quarts of oil without tripping the high level alarm. I had a dealer overpour on one of my changes back on my 335.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
07-20-2015, 03:01 PM | #12 |
1413
Rep 2,519
There is easily another quart in there that you won't get out in a normal oil change - oil cooler, head, etc. But either way, that is a TON of oil for a smallish engine. My 4.6L Rover V8 only takes 5 and a bit on a change. I wouldn't take it on a racetrack a quart low, but I would have no issues with driving it around normally.
07-20-2015, 03:29 PM | #13 | |
413
Rep 678
Did your TSX and Accord go such long distances between oil changes? Back in the day we would change every 3k miles or 3mths vs 12k or 1yr, which might account for not having to add oil in between changes?
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold |
07-20-2015, 04:14 PM | #14 | |
76
Rep 288
07-20-2015, 04:26 PM | #15 |
26
Rep 41
Every new car should be driven soft to break it in for a thousand miles or so, regardless of manufacturer or what your owners manual says.
I would also strongly recommend an oil change at 1200 to 1500 miles. Then drive it like you stole it. Turbo motors do burn more oil and it's not uncommon to have to add. It's not a horrible idea to have it looked at the first time you get the message though. I would. |
07-27-2015, 03:31 PM | #16 | |
123
Rep 241
Wrong. Please see this thread. http://www.2addicts.com/forums/showthread.php?t=1128783 I varied the RPMS a lot on my car. I kept it under 3500 for the first 500, 4k until 1,000 and then I introduced WOT...Raised it to 4500 at 4.5k and I constantly was shifting/varying RPMS. Changed the oil at 1,500 miles. I now have ~4k and I have burned zero oil according to the electronic dipstick. I bring it up to high RPMs often once it is warmed up and I let it idle approximately 30 seconds before I shut it off. |
07-27-2015, 08:18 PM | #17 | |
312
Rep 818
These car's aren't Porsche's. I agree with keeping it easy because the car does need to get used to RPM's but there is no foolproof proven way of breaking in an engine - there are hundreds of ways to break an engine in. My personal way of breaking my car in can be right too.. if you're solely going off of burned oil at 4,000 miles (which I'm currently at as well). Saying that is foolish - your break in won't be proven right or wrong until you near 100,000 miles of regular use. I agree with taking it easy for the first 1,000 miles but it's also said that high load, higher gear WOT pulls to ~4,500RPM help seat your rings as well. Hell, you'll still get people saying the ideal break in is with dino oil with very low rpm, just as you'll get people saying ideal break in is driving it like you stole it. Just because Porsche said it doesn't make it 100% right, it's just their way they've found to be the best. Thousands of people drive N55 engines off BMW lots with no word or care for break-in, and BMW knows this. These engines are mass-made engines for the masses, not one-off race/performance engines. No need to be such a dick about it. |
German1967578.50 |
08-07-2015, 03:38 PM | #18 |
Rep 56
I just wrote my 2010 135i off (N54) (140,000kms) so I don't have it anymore
I could never bring myself to wait as long as BMW told me to change the oil I did it every 10,000kms instead of the 20,000kms they recommended. That being said, there was not one time that I did not have to add at least 1 quart of oil betwen changes. If your burning oil you want to look into a walnut shell blasting when your at like 40,000-60,000 kms (i think its in and around 30,000 miles) Get it done routinely and have them change the plugs at the same time, plugs are not warranty and take a lot of labor to get gone but most of that labor is covered under the blasting which is warranty so you end up getting most of the labor on the plug change for free. |
02-01-2016, 11:12 PM | #19 |
29
Rep 195
The best part of trying to find BMW spec oil at every 1k miles is going to an auto store and having them turn pale and start sweating when you try to purchase fully synthetic oil.
02-11-2016, 06:47 AM | #20 |
Rep 53
Hi Kidu,
It might be discrepancy from dealers. Oil might not be sufficient at the time of delivery. You must visit dealers at the earliest and discuss with them. It might also because of leakage. |
02-23-2016, 11:12 PM | #21 |
119
Rep 213
My ti uses a quart every 2,500 miles, while the X3 is down 0.5 quart at the 7,500 mile change. Haven't had the 2er long enough to find out if it uses any oil. In any event, I wouldn't sweat 5,000 miles per quart oil consumption at all.
2014 M235i
2015 X1 xDrive28i M Sport 2009 Cooper Clubman 1999 Wrangler Sahara 1995 318ti Club Sport |
