07-18-2015, 04:14 PM | #1 |
95
Rep 338
BENT MY RIM! How to improve ride quality on h&r springs
Installed a killer set of morr wheels and dropped my car on h&r sports a month ago, but kept the struts and shocks stock. The car looks aesthetically so much better, but the ride quality just isn't there anymore. Anytime I hit a elevated part of the road going at a decent speed, it feels like my engine is going to drop out of my car.
I had it on a lift today, and I noticed a small bend on the rear right rim sigh. Probably from one of the numerous potholes I've hit in the last few weeks. Going to get it repaired sometime soon, but more importantly what kind of shocks should i install or other adjustments do I make to prevent this from happening again?? ive read people running h&r sports and bilstein shocks that have blown after potholes too. any members had better luck with a different combo? I feel like with the summer tires I'm running, any kind of bump I hit puts so much pressure on my rims because the springs are so stiff. Theres nowhere for the pressure to be absorbed except for the rim. Even forged rims bend in new jersey Last edited by kzflags; 07-18-2015 at 07:23 PM.. |
07-18-2015, 09:33 PM | #2 | |
1610
Rep 3,947
If you're on anything larger than 18" wheels, then the solution or adjustment you need to make should be self explanatory. Looking at the modifications you made, you have to realize that there are consequences to prioritizing looks over function. Last edited by Polo08816; 07-18-2015 at 09:39 PM.. |
07-18-2015, 09:54 PM | #3 |
95
Rep 338
07-19-2015, 07:55 AM | #6 |
1610
Rep 3,947
07-19-2015, 08:11 AM | #7 | |
103
Rep 335
07-19-2015, 09:41 AM | #8 | |
1610
Rep 3,947
It most often is: 1. Wheel diameter/sidewall height 2. RFT vs. non-RFT ... 3. Possibly suspension. If you search the forums, you'll be able to find many threads where people have damaged their wheels on a stock suspension. The common theme is they often live in pothole riddled areas and use 19+" wheels with RFTs. I have 35k miles on my 2014 335i M Sport with 18" OEM wheels. Zero issues with wheel damage from potholes. I've spent the majority of my time in MD and Central/North NJ. Advising the OP to spend additional money on a coilover system without addressing the most significant causes of wheel damage is misleading. |
07-19-2015, 01:06 PM | #9 | |
95
Rep 338
Im thinking about deflating my tires 1 or 2 psi to see if that helps. |
07-19-2015, 04:56 PM | #11 | |
Rep 13
In fact, as I see it, it's impossible for rim damage to result from too much tire pressure. Static pressure is a scalar; it has no direction, and therefore the pressure is applied equally to the entire surface (there's no more air pressure on the bottom of your wheel than on the top; the force supporting the car is transmitted through the tire bead to the rim). What I'm saying is that reducing your tire pressure will probably make this problem worse, not better. Last edited by educated_layman; 07-19-2015 at 04:58 PM.. Reason: more info |
07-19-2015, 05:03 PM | #12 | |
95
Rep 338
my thing is then, how does my rear rim bend when my 2 fronts are the ones taking most of the impact initially on severely uneven surfaces/potholes. |
07-19-2015, 05:09 PM | #13 |
Rep 13
I could speculate, but it would be...speculative. How many times have you experienced bent rear rims, and how many times have you experienced bent front rims? If the sample size is small, there's little sense in trying to attribute specific outcomes to anything systematic.
07-19-2015, 06:57 PM | #14 | |
1610
Rep 3,947
Your fix isn't going to be suspension related. It's going to be less diameter, taller sidewall, and/or non-runflat. But what certainly isn't practical, is fixing/replacing broken wheels all the time. |
07-20-2015, 12:22 PM | #15 | |
95
Rep 338
agreed, hopefully no more fixing in the future. wish H&R made it apparent how freaking STIFFF their springs were. |
07-20-2015, 02:04 PM | #16 | |
1610
Rep 3,947
But like what has been posted above, spring rates aren't going to have a significant impact on how wheels withstand pot hole damage. |
07-21-2015, 05:21 PM | #17 | |
95
Rep 338
got my wheels fixed though |
07-21-2015, 06:26 PM | #18 | |
103
Rep 335
Glad to hear that you got your Morr's straightened out.
Note the comment, "we were going over bumps on purpose and laughing at how nice they are." Xdrive with 245/35-19's on KW Street Comfort coilovers: http://f30.bimmerpost.com/forums/sho...&#post18064532 FWIW |
07-21-2015, 07:09 PM | #19 | |
95
Rep 338
but i agree with polo the problem of bending wheels is still the thin sidewalls. did some extensive research and chatted with the guy who fixed my wheels. are you on aftermarket wheels with your KWs? if so, youve had no trouble with the roads in NJ? |
07-21-2015, 07:18 PM | #20 | |
95
Rep 338
07-22-2015, 10:41 AM | #21 | |
103
Rep 335
My theory is this: When you hit a road hazard and the suspension is able to absorb the impact in its compression stroke without bottoming, some of the energy is transferred to the spring and damper. Once the suspension bottoms, though, the wheel and tire are caught between an unforgiving pothole and the momentum of a 3,800-lb car. I believe that this is where the greatest danger lies. I'm sure that someone will correct me if this interpretation is unfounded. My wheels are Apex EC-7's. Worst troubles I've had with wheels/tires in 50 years on NJ roads have been a few slow leaks. What did you learn from your extensive research and chat with the wheel guy? |
07-22-2015, 11:53 AM | #22 |
327
Rep 1,490
Former NJ'er, current MI'er. Two states notorious for having the worst roads in the country.
I have 19s, 245/40/19, "flow-forged" wheels, Dinan springs. This is the best setup, I haven't bent a single rim. Get the extra sidewall, it will help over the 30 profile. The H&Rs are too low/stiff for the roads in NJ, the shocks will help, but I think the ultimate solution is a better wheel/tire setup. Get Dinan springs which are more forgiving. Also make sure you research the appropriate tires, some tires will be a bit softer so that they will absorb impacts better. I also recommend buying a spare wheel. Avoid deep potholes at all costs. Drive slower through rough sections. I rode on 19s in NJ/Philadelphia for 2 years on my E90, I bent wheels a couple times. Even the 17s I had on my stock Acura bent catching a nasty pothole in Jersey City.
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
