Black Sapphire Metallic X5 - Corrected & Coated
07-14-2015, 11:42 AM | #1 |
360
Rep 5,052
The owner of this vehicle contacted us because she was unhappy with the current condition of the vehicle. The paint didn't look quite right to her, and she noticed that it looked more grey than black in some cases. During our initial consultation, we noted the large amount of surface defects and damage from previous detailers (dealership) that caused a dull and lifeless looking finish.
The owners were honest in that they do not always have the time to properly hand wash the car, and do prefer to take it through a car wash for convenience and time savings. With that in mind, we agreed that a full correction was not necessary, and decided on our Premium Service for a thorough cleaning, one-step correction process, and ceramic paint coating to provide easier maintenance and gloss that lasts. The car turned out great, and is now back to a deep, dark black with a tremendous shine! Process Tires: Tuf Shine Tire Cleaner and Tire Brush Wheels: Sonax FE, Wheel Woolies, EZ Detail Brush & other brushes Foam Pre-Soak: CarPro Iron X Snow Soap via DI Foam Lance Wash: CarPro Iron X Snow Soap Chemical Decon: CarPro Iron X Mechanical Decon: Medium Grade Speedy Prep Towel with Glide for lubrication Paint Thickness Readings Taken Masked off delicate areas Correction: Meguiar's D300 on MF Cutting Discs and very quick polishing pass with M205 on White LC Pad via Griot's BOSS 21, Rupes LHR21ES, and Rupes LHR75e CarPro Eraser Wipe Down Paint Coating: Optimum Gloss Coat Wheel Sealant: CarPro HydrO2 Tires: CarPro PERL Exhaust Tips: CG Metal Polish via #0000 Steel Wool and MF Towel Glass: CarPro Fast Glass Towels Interior: Vacuum, Glass cleaned, all surfaces cleaned with Einszett Plastic Cleaner or Quik Interior Detailer, Protected with 303 Engine: Rinsed, cleaned with Meguiar's D108 & Various Brushes, Blown Dry with Master Blaster, dressed with 303 Products available at www.DetailedImage.com The car was dropped off and was quite dirty Wheels were very dirty The dirt and grime left these wheels looking dull and lifeless. Exhaust tips had clearly never been polished and had an incredible amount of carbon buildup on them. As always, we begin by cleaning the wheels and tires. The tires were scrubbed several times to remove the dirt that had accumulated on them The tire cleaner stays white once all of the dirt has been removed. A liberal amount of wheel cleaner was sprayed onto each wheel and left to dwell. Looking much better! The wheels were then sealed for added protection We then turned our attention to the paint. The vehicle was covered in a thick layer of degreasing soap and all-purpose cleaner to help break through the thick layer of grime that had built up on the surface. The car was then carefully washed to remove any remaining loose dirt. The vehicle was then soaked in Iron X to remove any bonded iron particles from the paint. The chemical transforms from clear to purple as it reacts with iron and starts to dissolve it from the paint. You can see the chemical dripping from the paint. This vehicle was very contaminated. After the iron x treatment, the entire vehicle was clayed to ensure all bonded contaminates were removed. We then began with the paint correction process to remove the majority of light to moderate defects in order to enhance the gloss and color of the paint. Door before correction. Notice the complete lack of reflection near the lights. Door after correction. Notice you can now see the lights and the stool. The reflection was dramatically improved. Fender before correction. Fender after correction. Hood before correction - very dull due to improper buffing by the dealership detailer Hood after correction. Clarity and color have been restored. Rear quarter before correction. Again notice the dull reflection near the lights. After correction. Big improvement in clarity. Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
07-14-2015, 11:43 AM | #2 |
360
Rep 5,052
Exhaust tip before polishing
Exhaust tip after polishing. Unfortunately some of the metal was completely pitted and rusting, but still a great improvement overall. The glass was very dirty inside and out, you can see the passenger side is clean while the driver side has a thick film inside. The paint looked great afterwards Reflections were now clear and crisp Wheels and tires look great Engine cleaned up well with just a quick cleaning The paint is deep and glossy The sun popped out right before the owners arrived Before / After Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
07-28-2015, 02:32 PM | #3 |
51
Rep 308
Drives: 2007 328i
Very nice!
07-29-2015, 12:28 PM | #5 | |
360
Rep 5,052
Funny you mention that... they were commenting to me about how expensive the tires were lol Zach McGovern Detailed Image Ask-A-Pro Blog Author www.AttentiontoDetailingPeoria.com |
06-05-2017, 01:36 PM | #7 |
729
Rep 1,815
Wish I was near you.. My Black Sapphire 335i needs some tlc..
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
