07-13-2015, 11:21 PM | #1 |
23
Rep 84
Palmer Motor Sport Experience
I just got back from the track on Sunday and it was a big disappointment. My car was the slowest of them all. Even a stock Subaru WRX walk all over me.
The car is on A/S tires and it horrible with it! I wish I have gotten the RWD instead of the X Drive. This is great street car but not so much for the track. I will probably go again soon and get a set of new tires to see if this will make any differences. The A/S tires is garbage for the track. |
07-13-2015, 11:32 PM | #2 | |
1399
Rep 5,262
so you think x-drive is the issue ? |
07-13-2015, 11:40 PM | #5 | |
23
Rep 84
The track expensive changed my view on street cars vs track able cars. I went with a group of buddies and my car is supposed to be the best of them all. but it turns out very different on the track. I now understand the difference in the track vs the street. These WRX and Sti are actually very fast on the track. I have the fastest straight line car compare to my friends WRX and STI. On the track is a complete different story. My instructor can't even keep up with a novice driver with my A/S tires, that how bad it was. I think I will need to get better break pads and break fluid as well. Note: The stock WRX is on A/S Continental ExtremeContact DWS tires. Last edited by BBMMWW333; 07-13-2015 at 11:45 PM.. |
07-13-2015, 11:47 PM | #6 | |
1399
Rep 5,262
and what kind of mods did they have...? |
07-13-2015, 11:53 PM | #7 |
23
Rep 84
07-13-2015, 11:56 PM | #8 |
23
Rep 84
That's why I had my instructor test to drive the car. We know the tires is the main issue. but for him to have a hard time keeping up against a novice drive that is also on A/S tires in the WRX???? that's a big disappointment. Either the stock tires on my car is crap or the 4wheel drive system is not as good as the WRX.
07-13-2015, 11:58 PM | #9 | |
1399
Rep 5,262
What tires do the subbies have ? There is no way a stock FRS can be faster than the M235.... |
07-14-2015, 12:02 AM | #10 | |
1399
Rep 5,262
But usually 4wd it's not the best for the track anyway unless you are talking McLaren P1 4wd |
07-14-2015, 12:07 AM | #11 | |
23
Rep 84
The FRS is actually very good for that track. I am only able to use average of 40% -70% of the throttle based on the M Lap timer. The under steer is very bad with my setup. The tires screams on every turn at 40 - 50 mph. I'm not saying this is a bad car but the tire needs to go for sure. The current setup is very a good as a street car but it turns out to be a big disappointment for the track. ( I'm not trying to start a flame war here) |
07-14-2015, 12:11 AM | #12 |
23
Rep 84
I would think that the BMW Xdrive can't be that bad compare to the subarus. but I was wrong...
07-14-2015, 12:12 AM | #13 | |
1399
Rep 5,262
Also seems to be a quite twisty track http://www.palmermotorsportspark.com...aps.aspx?Map=0 quite a few hairpins and slow corners where you can't use much horsepower... Maybe an M235x with LSD would be a different story.. Was it dry ? can you post your laptimer file ? Last edited by pikcachu; 07-14-2015 at 12:18 AM.. |
07-14-2015, 12:23 AM | #14 | |
23
Rep 84
PM'ed |
07-14-2015, 12:26 AM | #15 | |
23
Rep 84
http://www.filedropper.com/20150712-...5194b2c8529ee6 |
07-14-2015, 12:39 AM | #16 | ||
215
Rep 661
Max speed 99mph? Really ? |
07-14-2015, 01:39 AM | #19 |
215
Rep 661
07-14-2015, 09:27 AM | #20 |
10658
Rep 6,937
Drives: 2018 M2 AW DCT
Remember guys, he is running on run flats. A very poor track tire.
But why is this posted in the NW section? |
07-14-2015, 08:58 PM | #22 |
127
Rep 765
OP: As you mentioned, there are probably a few things you need to fix.
1) Post this thread in the track section for more track-oriented feedback. 2) Flush your brake lines and use ATE 200 brake fluid. 3) Run flats are horrid, hopefully you did a good job destroying them. You should be able to find PSS sets for sale on here as one option. Other track drivers have moved to square setups on 17 or 18s, and camber plates to extend tire life. HPDEs are great events to learn more about your car and your own limits. Becoming a track rat requires forethought and planning - it can easily become an expensive hobby, albeit a fun one :P Enjoy the track and drive - nothing wrong with the car, just some minor tweaks to see some real improvements!
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
