Steering wheel still shaking...
07-04-2015, 10:03 AM | #1 |
160
Rep 2,016
Hey guys, I've had a vibration in my steering wheel around 40-50mph for a little bit now. I got my wheels and tires checked out, all straight, no bends, they're all balanced fine. So I was told to replace the control arms, just got that replaced and it's still there! It's incredibly annoying. Next step thrust arms? Any one have any idea?
EDIT: After 4 months it's fixed with a sticking caliper!!
Instagram~~"alexverdii"~~~
07-04-2015, 10:43 AM | #2 |
Is it the shoes!?
3884
Rep 5,112
Thrust arms & tie rods are the next place to look. Wheel bearings are another possibility, but those generally make a noise when they've gone bad. Start with the first two.
07-04-2015, 10:47 AM | #3 | |
160
Rep 2,016
07-04-2015, 11:29 AM | #4 |
340
Rep 1,744
Same here. I had the dealer do an alignment too since it was pulling to the right. Had balance done. The dealer said it is my tires. I don't how that's possible, brand new. I got them on in May. And it did the same thing with my old wheels and tires(winter setup).
07-04-2015, 11:45 AM | #5 | |
Is it the shoes!?
3884
Rep 5,112
07-04-2015, 12:20 PM | #6 | |
160
Rep 2,016
07-04-2015, 12:39 PM | #8 |
160
Rep 2,016
also if it means anything...the vibrations got worse with the new control arms, maybe its because that these control arms are more stiff and other parts of the suspension are messed up?
07-04-2015, 02:34 PM | #9 |
Rep 55
I believe the service of having your wheels balanced hasn't been done rite, or should given the information more specific then a "its fine"... The reason I'm aiming the balancing service rather then possible failed suspension is we'r over diagnosing (or mis-diagnose under are nose in some case).
When ever you come to have your wheels balanced, you want full info of what happening and I mean all, even if you just have new tires mounted. Some shop have upscale balance machine that's more clear look of what causing the vibration. Many causes can vibrate when it comes to the wheels and it only takes 1. You want to make sure you look and see the information the machine reads when balancing a wheel. The machine provide in: - Accurate tire pressure ( making sure both axel ,side to side, front and rear are in specs) - Measuring the rim for accuracy ( the machine knows your rim's dimensions and the differences of the front and rear if its staggered) - The important of reading Road force. The higher the number of each wheel, the more you will sense it times-what needed weights in any speed. And by watching the wheel turning in the machine... you could fine if the inner and outer bead of the tire are not sit onto the rim's lips all the way from mounting it, which is common. Check for out of round movement, the abnormal wear of cuppings as-well. So what I'm saying you want more then hearing a guy said to you on wheel balance "its ALL GOOD SON!" And yes when install in new suspensions, they are more stiffed to original ride quality or more, That will causes more sensitivity of the source causing the vibration. |
07-04-2015, 02:43 PM | #10 | |
160
Rep 2,016
07-04-2015, 02:43 PM | #11 |
Rep 55
- cool no problem,
I'll be more then happy to discuss the suspension. which means your going to need a lot of moving the fronts wheels around and see around for any wear out bushing. pics will be nice. And I'm sorry i get too technical im all about helping in hand all the way in diagnosing. |
07-04-2015, 11:44 PM | #12 |
886
Rep 2,720
Do u have BMW factory wheels or aftermarket?
Aftermarket wheels with diff offset makes steering wheel shimmer. When I got my after market wheels, there was steering shaking at 40-50mph. I was guided by a guy to get better thrust arms, eventually I upgraded to M3 lower/upper control arms complete assembly. I forgot the cost, it was around 260 or 360 something. M3 arms changes the steering response as well, it feels v good and the shaking went away. |
07-05-2015, 02:11 PM | #13 | |
160
Rep 2,016
07-05-2015, 05:44 PM | #14 |
Rep 95
Drives: 2007 335i FBO-JB4-METH-CELL PH
Please let us know how it goes with the thrust arms. I'm dealing with the same issue. Brand new tires, balanced 3 times, with spacers, without spacers, it is still there. Alignment is good. I'm thinking thrust arms as well.
07-05-2015, 09:05 PM | #15 |
Fastest 335 on Earth
39
Rep 426
Same here as well.
Replaced the tie rod ends, upper and lower control arms, struts. Vibration is still there
E92 335i, 6MT- YouWish Single turbo, Precision 6466, Doc Race intake manifold w/port injection, Precision Raceworks coil packs and Stage 3 lpfp, 3.46 geared Mfactory LSD, VRSF 3.5" single exhaust, Toyo R888Rs, Spec Stage 3+ clutch, DSS axles, RTD shifter, Motiv, boost box and flex fuel, WOTBOX, MOTIV tuned...and much more
07-05-2015, 09:05 PM | #16 | |
160
Rep 2,016
07-06-2015, 07:27 PM | #17 | |
12
Rep 80
The car does not seem to vibrate "in the seat" at highway speeds, and the brake pedal does not pulsate when braking. But I still get the shake at speeds around 40-60 mph, and a very noticeable shake in the steering wheel when braking from highway speeds. At a loss what to replace now, i'm thinking its either the rotors again, or a poorly done roadforce balance. Rotors were replaced about 40k miles ago. |
07-07-2015, 10:23 AM | #18 | ||
160
Rep 2,016
07-08-2015, 04:15 PM | #19 |
43
Rep 301
I just installed the m3 control and thrust arm kit in the front. Still have shuttering after 60mph. I also have Style 95 wheels. I got an alignment and the tires checked for balancing but the shuttering is still there. Annoying. Next step is to try road balancing or just throwing on my 18" stock wheels to see if its the wheel/tires themselves.
07-08-2015, 04:20 PM | #20 | |
160
Rep 2,016
07-08-2015, 04:23 PM | #21 |
Nomore
149
Rep 793
I had the same issue on a different car. Not a BMW. Ended up being the rotors. They must of been rubbing the pads as the spun unevenly and created a pulsing vibration feel.
I was surprised when that fixed it. Car also drive smoother. Also a bad caliper can do the same in reverse to a somewhat out-of-round rotor. But obviously you must first check: Wheel balancing Tire hop/wobble Suspension bushings Worn out suspension parts Alignment |
07-08-2015, 05:22 PM | #22 | |
Is it the shoes!?
3884
Rep 5,112
Other things that can cause vibrations are tires, or if the wheels are bent. Bent wheels are a lot rarer, and you generally know when you've bent a wheel; it'll be a pothole you don't forget! Bent wheel repair is fairly cheap, though. Usually you can get a sweet full refinish deal out of it and have nice shiny new rims. I would trust what your mechanic suggests. He can see the car, whereas I can only go with what has worked for me on past BMWs in similar situations. |
