07-02-2015, 06:32 PM | #1 |
732
Rep 10,104
ACM | Coding Special $80
All coding in house at our shop located in Van Nuys
Section 1 Coding Options: Activating/disabling of features Section 2 Retrofit Coding: Adding/Removing/Disabling Hardware (Such as alarm) Section 3 Software Flashes: Updating modules in the vehicle (update to current software, or performance software) Please Read: *Coding is customized to your taste, please select options that relate to your life style, needs/ wants *All coding done is warranty & dealer friendly. No software is added or removed from the vehicle. *If you do not see a coding option that you like to have, please ask. *If you have aftermarket lighting, please notify before your session. F2X/F3X/F8X Coding Options Comfort/Lighting Options: Euro MDM Disable Seat Belt Chimes (Passenger, Driver, or both) Disable Seat Belt Warning Windows up/down & closing/opening of sunroof with key Windows up & closing of sunroof with Comfort Access (Comfort Access required) Folding Mirrors with key Folding Mirrors with Comfort Access (Comfort Access required) Unlock doors when engine is turned off Window safety feature (When window is rolling up, you can open the door without it stopping, one touch operation of windows with door open) Welcome Lights Fog Lights (When you hit unlock, your fog lights come on) Removal of Amber Headlight Sidemarkers (Euro Look, will only come on when you signal) (Excludes LED Headlamps) Fog Lamps with High Beams (Fog lights will not shut off when high beams are activated) Turn Off Daytime Running Lights Digital Speed Display (Speed will be displayed in numbers center of the cluster, added option does not remove anything, M3 style) Adjust Low Fuel Warning (Standard 1/8 can be moved to 1/4) Flashing Brake Lights (Brake Force Display) (Upon hard braking the brake lights will flash) Increase Triple Blinker Blinks (Increase from 3 blinks to as high as 7) Door handle LED on in reverse Increase Ambient Lighting (standard 60%) Auto Start/Stop feature default to off or memory Sports Display (Display HP and TQ gauges, limited to select vehicles) Enable Sports+ Mode (please verify you DO NOT have this before adding it to your list) Close tailgate with key and inside cabin button (For GT models only) iDrive/Navigation Options: Enable DVDinMotion (Watch DVDs at any speed for cars with navigation) Removal of iDrive Disclaimer Message (no more pushing accept when first starting the car) Add Fuel Stop Proposals (standard on 2011+ cars) (For 2009+ cars only) Enable Weather band (limited to some vehicles) 8 Shortcut buttons (standard US vehicles have 6 shortcut buttons, you can make your AM/FM and mode button to shortcut 7 & 8 but you lose your AM/FM & mode button function) Inband Ringtone (transfers the ringtone from your phone) M Start up screen (Standard on M3/4, only works on cars with NBT units) Video through USB (cars with NBT only, will not work on CIC) Enhanced Bluetooth/USB (6NS enable streaming Audio through your phone, and video through USB, video only NBT) Digital Tire Display (Display temp and PSI of tires) F2X/F3X/F8X Retrofit Coding * All hardware must be installed/removed before coding Bulb warning removal (after market HID/LED installs, you must know which bulbs are giving an error, cannot turn off all bulb check warnings, not safe) Race Seat Coding (Removal of Airbag/MRS/SRS errors) *Will only code airbags that are fully removed, everything else will stay active Roll cage coding (Removal of Airbag/MRS/SRS errors) *Will only code airbags that are fully removed, everything else will stay active Alarm Coding (Activation of factory alarm) Removal of EDC (Electronic Damping Control) (EDC module must be disconnected) Removal of TPMS (Tire Pressure Monitor) (TPMS module must be disconnected) CIC Retrofit/NBT Retrofit Rear fog light retrofit (Requires euro light switch, or modification of US light switch) E-MAIL for any other retrofits or removal of hardware Activation of Sirius Satellite Radio (Includes 1 year free of Sirius 2010+ Cars with iDrive) Activation of BMW Apps (requires Combox, please email last 7 of vin to check) Navigation Map Updates F2X/F3X/F8X Software Flashes Email for pricing Engine Management software update (enjoy the most update to date software for your vehicles engine DME) *Not available to remote coding customers Update any module in your car Transmission update (update the software for your transmission, helps with shifting, improves gas mileage) Contact through PM or give a call (818)-849-6282 Come see us at 14212 Oxnard St Van Nuys, CA 91401 |
