02-15-2008, 07:54 PM | #1 |
Reincarnated
245
Rep 4,227
Tire Rack E92 M3 Goods
Tire Rack has updated their site and now lists wheels and winter items for the M3. They also have information on tires, floormats, and suspension.
The photo isn't up to view on the vehicle, but at least you know what fits.
02-15-2008, 07:58 PM | #3 |
Reincarnated
245
Rep 4,227
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Beautiful!! Closeout pricing on the fronts too!
02-15-2008, 08:10 PM | #4 |
Reincarnated
245
Rep 4,227
02-15-2008, 08:15 PM | #7 |
Reincarnated
245
Rep 4,227
I love the diamond black look. Reminds me of the Concept's wheels and a lip always looks good on a BMW.
02-15-2008, 08:27 PM | #9 | |
44
Rep 544
those will cost me less then 1k shipped then I guess tires will be another k
08' e92 M3 6MT // Rogue SSK // B&B Tri Flow Exhaust // AA air filter // Mod Carbon Skirt extensions // Amuse Front/Rear Bumper // Amuse Trunk // Gloss Black Grills w/ M colors // gloss black side vents // M5 Stick with IND custom stitched boot // Carbon Firber wrap steering wheel trim // Avant Garde M364 20' (street) // Advan RS 18's (track) |
02-15-2008, 08:30 PM | #11 |
755
Rep 2,736
Agreed on all counts. Not too dark, excellent lip and you can never go wrong with some variety of the old school basket weave wheel. The lip is nicely machined to give just a hint of sheen. A little understated, but it catches your eye. The forks are far enough apart and extend close to the leading edge, to offer the illusion of a larger wheel. This also allows for easier cleaning and more photo ops for the subsequent BBK!
02-15-2008, 08:49 PM | #12 | |
374
Rep 8,033
I told you getting the stock 18"ers is asking for trouble... Those BBS wheels are king. They are about 7-8 lbs lighter than the stock 19"ers. I suspect the Breyton wheels are not nearly as light and most likely don't have ideal off sets either, but they do look great on the M3. |
02-15-2008, 08:58 PM | #13 | |
Reincarnated
245
Rep 4,227
Aftermarket can be a problem. I had a problem with the hub rings heat-seizing to the hub and the wheel center bore. Took some crazy banging on the tire to pop them loose to remove the wheels. That's why I would like to get a wheel that has the correct centrer bore for the model. I notice some of the forum sponors make wheels with identical specs. Those BBS wheels don't have the correct offsets either, right? Yup, $17k a year.
02-15-2008, 09:01 PM | #14 |
Reincarnated
245
Rep 4,227
No, just saw them tonight.
02-15-2008, 09:07 PM | #15 |
O! So Sour!!
552
Rep 15,615
Drives: Fast 240z / Slow M3
I dont think the 0 on your keyboard is working...
02-15-2008, 09:25 PM | #16 |
374
Rep 8,033
02-15-2008, 10:11 PM | #17 |
125
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
I'm loving the BBS RGRs, they are sweet. I wonder if I can get a 19x9 for all 4 corners for my track wheels and then use 7mm spacers at the back to compensate for the different offset on the back wheels. That way I can rotate tires front to back for longer life on the track.
If not, I could use the 19x8.5s at all four corners with spacers.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
02-16-2008, 02:49 AM | #18 | |
Moderator / European Editor
1499
Rep 6,755
But wait, made in China? +1 Guess they're quite heavy, though. Best regards, south |
02-16-2008, 02:52 AM | #19 | ||
1499
Rep 6,755
02-16-2008, 07:27 AM | #20 |
62
Rep 800
Drives: '08 E92 M3
What's the difference between a centering ring and a spacer? I assume the centering ring accommodates smaller hub diameters?
'16 F30 340i xDrive 6MT Melbourne/Black '08 E92 M3 6MT Jerez/Speed Cloth '18 F80 M3 6MT SO/CSAT |
02-16-2008, 08:12 AM | #21 |
755
Rep 2,736
A centering ring does accomodate smaller hub sizes whereas a spacer creates less offset. You want only hubcentric spacers if you go that route. I rather select wheels that are model specific than use centering rings. Quality hubcentric spacers are okay, but again if you can find the correct offset for your model and liking, that's the way to go.
02-16-2008, 08:42 AM | #22 |
Reincarnated
245
Rep 4,227
Check my order thread for details. BMWUSA told my dealer they couldn't be ordered even with a late Feb build.
