2011 e90 328i Battery Replacement $700??
06-26-2015, 11:33 AM | #1 |
16
Rep 62
Hi There,
My battery died on me two nights ago and I took my car to BMW dealership... They quoted me $700 to replace a battery. Battery itself is only $250, but they charged about $450 for labor since they have to "register" the battery to my car. I just thought this was ridiculous and walked out. I was thinking about replacing a battery myself or taking it to indy shop. Have you guys done DIY on battery replacement? "Registering" is really necessary? if not i would like to DIY, if not i should take it to indy shop. Any advice is greatly appreciated, folks! |
06-26-2015, 11:46 AM | #3 |
1920
Rep 13,122
Yes you should do the later or DIY.
Do not use battery back up it blows fuses. Do not close the trunk its and electric lock. There are DIY procedures in the DIY and maintenance section there and on ytube. You could buy the Carly (BMWhat) app and register it yourself and then have diagnostic and programming capabilty so you don't get messed with in the future. About 120 with cable or wi fi dongle. And Indy or Coder will register it for between 25 and 50 bucks. A really good Interstate Battery will run you a little under 200 bucks and a lot of people get a Walmart battery for between 100 and 150. It's usually a group 49/h8 ot 49/h7 I paid 250 for an INterstate MTP 49/h8 installed and registered at an Indy. Last edited by ctuna; 06-26-2015 at 11:53 AM.. |
06-26-2015, 12:20 PM | #4 | |
16
Rep 62
I am not planning to buy an OEM one, so hopefully that's okay. have you ever used Carly App in the past? How intuitive or easy is it?! Thanks a lot |
06-26-2015, 12:28 PM | #5 |
1920
Rep 13,122
The most important thing to match is amp/hours
or get close most of the stock ones are 90 amp hours(usually) so something that meets or exceeds that it will be a group 49/h8 or h7. Be sure to install the vent tube. Take a picture of the wiring before diss assembly . Vist the Carly app site I would say its very user friendly from the adverts. I have a coding setup already but if I didn't I think the Carly app is the way to go. Its easy and fairly foolproof and doesn't cost a lot compared to alternatives. There are demos on ytube I believe. There are plenty of coders in LA. See coding sub forum. electical e90 pdf http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja http://www.google.com/url?sa=t&rct=j...85464276,d.cGU http://www.google.com/url?sa=t&rct=j...85464276,d.cGU read the first pdf with regards to the battery distribution block . Last edited by ctuna; 06-26-2015 at 12:37 PM.. |
06-26-2015, 12:32 PM | #6 | |
16
Rep 62
Appreciate it a lot |
06-26-2015, 12:33 PM | #7 |
16
Rep 62
06-26-2015, 12:35 PM | #8 |
More Boost?
59
Rep 283
06-26-2015, 12:36 PM | #9 |
7478
Rep 10,120
06-26-2015, 12:40 PM | #10 |
895
Rep 3,141
WOW. Total ripoff. Went to a BMW Indy. They put in the Bosch brand that BMW uses, install, program was $325.00. It took the the tech approximately 30 minutes to remove the battery. I'd say another 20-30 to register it. My car is a 2008 328i.I don't go to the dealer for anything. Several times they tried to upsell me unnecessary repairs that cost in the thousands. Really unethical practice most dealers have. Good luck OP. Stay away from the dealer if you can.
06-26-2015, 12:52 PM | #14 | |
16
Rep 62
06-26-2015, 12:53 PM | #15 |
16
Rep 62
My SA put in 1.5 of hours, and their hourly rate is about $200. That being said, that's $300 in labor, plus tax and registration plus battery came out to be like $688.
06-26-2015, 12:55 PM | #16 |
16
Rep 62
06-26-2015, 12:56 PM | #17 |
228
Rep 1,049
The Carly app currently lets you 'register' BMW battery (which tells it 'new battery' for charge profile purposes), but it currently lacks any ability to code the car to recognize a DIFFERENT TYPE & CAPACITY than the battery which is being replaced.
You do not have to immediately 'register' a battery, but be aware that you can eventually run into either
06-26-2015, 01:22 PM | #18 | |
16
Rep 62
06-26-2015, 01:26 PM | #19 |
douchebaggo
186
Rep 972
From what i've heard, the price of OEM battery has skyrocketed the past 2 years as BMW changed vendors.
Talk to Charlie at Mckenna. He quoted $475 out the door couple weeks ago. That's quite reasonable for OEM at a dealership. |
06-26-2015, 02:44 PM | #21 |
Where'd my VTEC go?
481
Rep 6,067
There's no good reason to pay a premium for the OEM battery when you can get a battery at Autozone for $100. You should be able to install and register it at an indy for cheap or DIY if you know how to code.
06-26-2015, 03:04 PM | #22 | |
39
Rep 592
Dealerships are charging 1.5 hours for labor? WTF?? It was my first time on my e90 and did it in 15 minutes TOPS! |
