06-24-2015, 01:07 AM | #1 |
23
Rep 84
M235i Coding Done!
Alex @ 917-681-1833 Coded my car in NY, Queens today.
Unlock door engine off close all/open windows/roof using FOB Auto Radio/Navi off when engine off Door handle Led in parking mode Video in motion Remove Disclaimer M Theme display with start up Auto mirror fold and unfold with fob & door handle 5 blinks with quick turn signal instead of 3 Is there anything that I should add such as M car engine noise? Last edited by BBMMWW333; 06-24-2015 at 01:22 AM.. |
06-24-2015, 01:51 AM | #2 | |
1399
Rep 5,262
backup camera is motion is cool too as well as european emergency blinking brake lights and variable light distribution |
06-25-2015, 10:44 PM | #3 |
23
Rep 84
We tried the European blinker light, it did not work.
I also did the wide view light coding but only the driver side light goes to the left. The passenger side remains the same. Is this correct? |
06-25-2015, 10:52 PM | #4 | |
1399
Rep 5,262
VLD description "Variable Light Distribution technology, optimises visibility under many driving conditions. The road speed dependant system automatically enlarges the driver’s field of visibility by broadening the light beam, or the “footprint” of light. In a typical city night-time driving situation at speeds below 50 km/h, the system ensures a broader distribution of light making it easier to recognise objects on the oncoming side of the road. In freeway mode, the driver’s field of vision is extended by giving the light beam a longer range, and again offering greater illumination on the far side of the road. Activation of the fog lamps at speeds of up to 70 km/h also generates broader light distribution and brightens up the area close to the car. At higher speeds, the headlight range is also extended over and above the broader distribution of light. Variable Light Distribution has several different modes of operation (for Low Beam): 1 - City Light: Shallow and Very Wide Beam Pattern active from 0 - 50kph (30MPH) (Both Headlamps are Panned outwards 12° horizontal from center and 0.7° lowered vertically) 2 - Standard Light: Same Basic Beam Pattern as with 8S4 Enabled and Headlamp Switch Set to Auto. Active from 50 - 110kph (30MPH - 68MPH) 3 - Guiding Fog Light - Shallow and Wider Beam Pattern Enabled with the Front Fog Lamps On and Headlamp Switch in Auto and Speed 0 - 110kph (Both headlamps are panned outwards 8° horizontal from center and lowered 0.7° vertically) 4 - Highway Light - Long Throw Pattern illuminating approx. 25% further than Standard Light. Active from 110 to 250kph (68MPH- 155MHP). (Driver's Side Headlamp is panned 3.5° outwards Horizontal from center and lowered 0.25° vertically, while the passenger side headlamp is raised 0.2° vertical)" |
06-25-2015, 11:02 PM | #5 |
23
Rep 84
Based on my video, is this correct? I feel like the left lane is brighter and my right lane stays the same. In a way, it felt like I had my steering wheel on the left making a turn. Only the driver side light moves to the left side when in Drive.
06-25-2015, 11:22 PM | #6 | |
1399
Rep 5,262
for the european blink you need to be braking in motion... they won't blink if you step on the brakes while parked |
06-25-2015, 11:31 PM | #7 | |
23
Rep 84
My buddy coded European blinker but we thought it was supposed to blink twice when we put on the hazards light or turn signal. Last edited by BBMMWW333; 06-25-2015 at 11:48 PM.. |
06-26-2015, 12:01 AM | #8 |
1399
Rep 5,262
06-26-2015, 12:36 AM | #11 |
23
Rep 84
06-26-2015, 12:52 AM | #13 | |
23
Rep 84
What Emergency brake light threshold speed should I set? Last edited by BBMMWW333; 06-26-2015 at 01:12 AM.. |
06-26-2015, 08:34 AM | #14 |
1399
Rep 5,262
12-31-2015, 02:30 PM | #15 |
Rep 47
Will the European style brake light blinking activate every time I brake, or only when I emergency brake - ie when the ABS kicks in?
2016 M235i RWD 8AT Black Sapphire
12-31-2015, 03:30 PM | #16 | |
1399
Rep 5,262
01-01-2016, 10:04 PM | #17 | |
609
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
