Thanks
06-05-2015, 02:59 AM | #1 |
Գեվոջանյան
301
Rep 1,103
Thanks
Current: 23 Frozen Gray M8 Comp GC, 22 Viola Parsifae Lamborghini Urus, 11 Fire Orange E92 M3 6MT, 07 BSM E60 M5 6MT, 00 Imola E39 M5
Previous: 2019 BSM F90 M5 Comp, 2019 Giallo Auge Lamborghini Urus, 2011 Silverstone E92 M3 Last edited by M.Power; 10-09-2015 at 02:17 AM.. |
06-05-2015, 03:05 AM | #2 |
128
Rep 664
Its your rear brake pads or the handbrake shoes. It gets worse...a lot worse. By the time I took mine in for this, everywhere I drove under 40mph it sounded like I was dragging a sword on the road behind me.
08 E92 335xi 6AT, Sapphire Black Metallic
Modlist: 19x8.5+32/19x9.5+35 BBS CH-R Black, Michelin PSS 225/35/19 - 255/30/19, rolled rear fenders | KW v3 coilovers | Akrapovic exhaust Keep it on the black stuff shiny side up! |
06-05-2015, 03:07 AM | #3 | |
4542
Rep 11,903
Mine was rattling until I filled it with foam rubber |
06-05-2015, 03:13 AM | #4 |
Գեվոջանյան
301
Rep 1,103
Definitely not that, it doesn't come from the inside of the car and gets especially loud when my windows are open and I am going over a bump.
Previous: 2019 BSM F90 M5 Comp, 2019 Giallo Auge Lamborghini Urus, 2011 Silverstone E92 M3 |
06-05-2015, 03:13 AM | #5 |
Գեվոջանյան
301
Rep 1,103
I'm pretty sure its the handbrake shoes, pads look like they have atleast 50%, how could I check if its this? And thank you both for the replies.
06-05-2015, 03:14 AM | #6 |
4542
Rep 11,903
06-05-2015, 03:21 AM | #7 |
Գեվոջանյան
301
Rep 1,103
The car is dropped, but I bought it like this and haven't touched it so not sure, I was suspecting that too. One of the wheel bearings was bad when I got it so I thought maybe that was the problem.. I replaced the wheel bearing and the sound didn't go away. And my other wheel bearing went out since then... Lol I love this car
06-05-2015, 03:43 AM | #8 |
128
Rep 664
If you pull the handbrake up a touch, does the noise stop? That would be your best indicator.
06-05-2015, 12:07 PM | #9 |
Գեվոջանյան
301
Rep 1,103
I'm going to drive for a second with the handbrake on today to see, haha.
06-05-2015, 01:58 PM | #11 |
48
Rep 361
If you had the squeak for a while, especially when parking brake is engaged:
90% ebrake shoes 5% bushing (near the wheel, maybe lower control arm) 5% ball joint |
06-06-2015, 12:40 AM | #12 |
Գեվոջանյան
301
Rep 1,103
I just did what you guys told me and drove slow on first gear while engaging the hand brake and the sound still occurred while doing that.
06-06-2015, 03:45 AM | #13 |
128
Rep 664
I still think its your brake pads.
06-06-2015, 07:36 AM | #14 |
1208
Rep 2,835
With engine off, put the car in park (or what ever gear for manual) and do not engage the hand brake, find a good spot on the rear corner of the car where the sheet metal will stand being pushed on and shove down hard several times and then do the other side. If you hear the squeak it is something in your suspension.
If that doesn't cause it to show up, find a parking lot and drive slow and touch your brakes (not the hand brake) and see if it gets louder or disappears. If it does one or the other then it is something with the rear brakes. Squeaky hand brake shoes/mechanics ususally shows up when it is engaged and a person is getting in and out of the car. You can check that by not engaging the hand brake and getting in and out of the car and then disengaging it and getting in and out. |
06-07-2015, 09:04 AM | #15 | |
36
Rep 106
E-Brake shoes can likely just be cleaned, if that is the culprit. Brake dust builds up IMMENSELY in that area.
-Mike
2008 335i 6MT Coupe Sapphire Black Metallic / Saddle Brown Last edited by Air Drop; 06-07-2015 at 09:05 AM.. Reason: spelling error |
