05-31-2015, 06:11 PM | #1 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
what brakes do I have?
Do I have standard, M-Sport upgrade or the M Performance brakes?
My car is an M-Sport, and it has the unpainted Brembos....so im assuming the M-Sport upgrade? im looking to replaced to rotors to drilled/slotted.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
05-31-2015, 07:24 PM | #3 |
3572
Rep 10,352
Your front calipers are the same as those who opt for the M-Sport Brakes or the M-Performance Brakes. Your rotors are not the same size however (~345mm vs 370mm)
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
06-01-2015, 05:37 AM | #4 |
Rep 35
Your fronts could be either 340x30 or 370x30 depending on year and options. Grey will likely be the 340,s. The larger disc will be paired with the 2 piston rears as noted above. I have read the caliper for the 370 rotor has a slightly different bridge than the virtually identical 4 piston one designed for the 340 rotor. I have never actually confirmed this.
Best to measure the diameter of your existing rotors with a tape measure The difference in diameter is about an inch and should be readily obvious with a tape measure. or even better check the rotor part number on the hub against info on the turner motorsports website re brake system differences. Last edited by johnsjmc; 06-01-2015 at 06:21 AM.. |
