2006 330i won't start won't start
05-25-2015, 08:15 PM | #1 |
Rep 8
Hey all I'm new to this forum I have an issue with my car it won't start every time I try to start it it makes a clicking noise I was reading it could be the starter but not sure could it be a fuse or something help!! Thanks
05-25-2015, 09:40 PM | #4 |
71
Rep 244
05-25-2015, 10:22 PM | #5 |
113
Rep 450
If your car doesn't start:
1. If you have no power at all, your battery is dead. Charge the battery or replace it. 2. If your accessories have power, try to jump start it. If it starts, your battery is too old. Replace battery. 3. If it doesn't start, it's probably your starter. Especially if you have close to 100k miles or more on the original starter. This is the case 99% of the time. This happened to me at about 100k miles. |
05-26-2015, 12:09 AM | #6 |
71
Rep 244
Have the battery load tested. That's how you know for sure. I've experienced a couple times where even trying to jump start the car wouldn't work. Turned out to be the battery and not the starter.
05-26-2015, 12:12 AM | #7 |
Rep 8
All my electronics work all the windows roll down radio works lights work except for the car it just won't turn over I'm pretty positive it's the starter but just wanted to make sure it's not a fuse or something any idea how much it'll cost to get it fix car has 109k miles on it
05-26-2015, 12:20 AM | #8 |
71
Rep 244
And I'm pretty positive that you have a bad battery. The electronics still working doesn't really mean anything because a battery with 11.5 volts will operate your electronics but will not start your car. Seriously, have your battery load tested before you even think about the starter. Most auto parts stores will do load testing for FREE.
05-26-2015, 10:11 PM | #10 |
Rep 8
Well I took the battery to get it checked it turns out it was bad I bought a new one and still the car won't turn over now I hear a noise in the engine whenever I try to turn it on so any more suggestions on what could it be all the electronics work fine
Tags |
2006, 330i |
