Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Wall bumps, are these a flaw on the RFTs?
      02-09-2008, 05:56 PM   #1
Flat Out 32
Flat Out 32's Avatar
16
Drives: my feet.
Need to change a tire, the 3rd in three months due to bumps in the outer walls. Is this a common issue with run flats? Is reverting to regular tires gonna make things easier rather than spending on a new tire monthly? The car is used twice a week so its not a daily driver. For those of you with knowledge in this field please comment. I thank you a lot!
Georgie Vazquez
Mayaguez, PR
R.I.P. 335i, 010 135i here!
      02-10-2008, 12:18 AM   #2
Flat Out 32
16
Drives: my feet.
I've found out, so far, that the walls having the characteristic of holding up the weight tend to deform upon compression. Please confirm, all speculations!
Georgie Vazquez
Mayaguez, PR
      02-10-2008, 12:25 AM   #3
BMW MotorSport
100
Drives: 95 Avus M3 and 07 E90 Fam Car!
I don't believe that this is normal tire behavior. You should not be getting any side bumps on your tires even if you don't drive it very much. This is why I hate run flats, they are heavy, expensive, poor handling, and noisy.
NRFT>RFT
      02-10-2008, 10:39 AM   #4
Flat Out 32
16
Drives: my feet.
NRFT>RFT
Thanks a lot for your input, so you think its better off running non RFTs? Is there an advantage or loss regarding wheel protection and tire protectioon against side bumps from potholes? I thank you once more!
Georgie Vazquez
Mayaguez, PR
      02-18-2008, 01:19 PM   #5
turboso
67
Drives: 18imolaf80CP
same happend to my wife's car that sucks. Mine's probable that she drives with her eyes closed.lolol
      02-18-2008, 06:01 PM   #6
de.abeja
Drives: 335 sedan
I had one on my passenger front tire, took it to the dealer and they shrugged and said idunno... so I took it to a firestone tire shop. The first shlep that helped me said it was my fault before I even told him the story, the manager listened and said that if there was no evidence on the inside of the tire from an impact or foreign object damage they would just warranty the tire (@ 9000miles).
I think the sidewall blisters are a defect or poorly manufactured tires just because I have heard from more than one member on here that they have also incurred mystery sidewall blisters.
