F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > xDrive lowering springs. New bump stops or no?
proTUNING Freaks
      05-21-2015, 07:48 PM   #1
crono06
crono06's Avatar
127
Drives: 2013 335i and 2018 X3
I'm looking to get some very mild lowering springs for my car (probably going with Dinan or AC Schnitzer) and I wanted to find out what the consensus was on new bump stops?
For those of you who put lowering springs on your car, did you get new (shorter) bump stops with them? Since the drop will only be ~1 inch, I'm wondering if I will see any noticeable difference in day to day driving?
And I know that there will probably be people who suggest coils instead. I have DHP and need to drive my car year round. I'd like to retain my adaptive shocks functionality and not worry about the coils getting destroyed by the tremendous amounts of salt and brine used to cover our roads in the winter.
      05-21-2015, 08:44 PM   #2
jon102034050
Drives: 2014 335i xDrive
I havent done suspension (yet!) but from what I hear from my Dinan dealer the bumpstops should definitely be used.
      05-21-2015, 11:11 PM   #3
sandwi54
sandwi54's Avatar
538
Drives: G07, F90
Definitely use the bump stops. You'll regret if you don't because you'll get really sick of bottoming out all the time, and end up paying twice for installation.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD)
      05-22-2015, 05:24 PM   #4
mdavis12
El Presidente
mdavis12's Avatar
19
Drives: 328i xdrive
you'll bottom out even with the bump stops. so i would image this would happen a lot more without. so definitely get both
      05-23-2015, 11:42 AM   #5
RM7
RM7's Avatar
2893
Drives: Camaro SS 1LE
So if one was to use other springs, like ACS (because Dinan doesn't make ones for my model), aftermarket (Dinan) bumpstops should still be used?
      05-23-2015, 11:58 AM   #6
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
Only change the springs. Leave everything else in place. BTW ACS drop is nicely noticeable in looks and cornering
I parked next to a stock M4, and I was a tad lower.
      05-23-2015, 05:16 PM   #7
Titan 3
Titan 3's Avatar
101
Drives: E46 325ci ~ F36 428ix
I used the H&R Sports on my AWD and left OEM bump stops in place. They never bottomed out at all. I have a Gran Coupe X and found it was slightly lower than an RWD sport suspension counterpart. I enjoyed the H&R's so something to consider there.
      05-25-2015, 08:09 AM   #8
crono06
crono06's Avatar
127
Thanks for the input. I am highly considering the Dinan or ACS springs. From what I saw in members' posts, both of these seem to give the level of drop that I am ideally looking for. The only problem is that ACS is not exactly easy to get here in the Toronto area, and they are quite a bit more expensive (due to weak CAD).
I was considering H&R as well (as it is cheaper than either of the other 2 options) but it might be a bit low for me (I'll have to drive this year round). Titan, it is good to know that you haven't bottomed out with the H&R springs though as they are about half an inch lower than the other 2 options I'm looking at.
      05-25-2015, 06:42 PM   #9
andrew 330i
it can never be too clean...
andrew 330i's Avatar
163
Drives: 2014 F31 M Sport Wagon
~ the sad thing... dinan bump stops are nothing more than factory/oem bmw parts.
I ordered a set when I installed h&r sport springs on my 2014 wagon...and if I recall with cross-referencing, the fronts were e36 m3 bump stops and the rears were 5 series bump stops.
'14 328xi wagon / m sport / white / red leather
kw v1 coilover kit / 19" staggered 351 M double spoke wheels / upper strut bar /
sport line grille & exhaust tips / 50% tint / painted reflectors / debadged / complete clear bra
      05-25-2015, 07:25 PM   #10
crono06
crono06's Avatar
127
Yes, I recall reading this somewhere as well that they were just oem parts but for other vehicles. I just wasn't sure of the models so I didn't want to spread it around since I couldn't back it up lol.
      04-25-2019, 12:25 PM   #11
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
I installed CATuned coilovers and lowered mine, I ended up using the stock bump stops. I had to trim them shorter to make them work but I had no issues since I installed them last summer.
Not promoting coilovers for you, I dropped mine a couple of inches.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
      04-25-2019, 08:06 PM   #12
henkinc
16
Drives: F30 335xi MT
Dinan vs Eibach progressive springs on 335Xi Adaptive suspension
I confess I am no student of the OEM parts use this thread explores and don't really care - my interest is in the functionality of the "Dinan" bump stops. The difference against my stock Bumps Dinan says is the use of a spring element in the top, so there is not a "hard" stop. Makes sense. If Dinan strongly recommends it I would use them with their 3/4 inch lowering springs on a Xi F30.
Eibach Pro-kit however is a progressive spring and logically would not bottom out as much as a linear spring. Hence less need for the new stops.
HOWEVER, I have not installed either on my F30 335Xi and am eager to hear from anyone who has done so on the adaptive suspension F30. Please inform us if you have. I would not particularly be interested in RWD or non-adaptive suspension spring upgrades since these are heavily threaded on bimmerfest. (I guess no one with my setup wants a slight lowering and less sway with decent ride quality?)
btw, my car has Dinan stage 1 performance with Evolution Racewerks Charge Pipe, Manual trans, and quicker clutch engagement ($10 part). SO it is halfway decent now but clearly the suspension on these cars is a relative weak point, cosmetics of lowering aside.
Thanks.
      04-25-2019, 09:31 PM   #13
harperium
harperium's Avatar
1313
Drives: G80 M3cx
I have the Dinan springs + bump stops. Worth getting both.
Also don’t forget to get stiffer dampers; the Dinan springs will overpower the stock shocks.
      04-25-2019, 10:09 PM   #14
henkinc
16
Harperium - do you have adaptive suspension?
The only aftermarket for the electronically adjustable shocks seems to be Bilstein, which advertise improved handling but otherwise stock setup. I believe they can take 30mm lowering which is the Dinan spring lowering amount.
Do you have adaptive shocks as OEM?
f30post
