Manual Transmission Fluid
05-16-2015, 10:07 PM | #1 |
Rep 36
My car is at 97k so I am thinking a transmission fluid change is in the near future. I have narrowed down to Redline D4 and D6 ATF. I heard the D4 is better in hot climates. Is this true? Thanks!
05-16-2015, 10:17 PM | #2 |
533
Rep 2,872
05-16-2015, 10:57 PM | #3 |
1917
Rep 13,114
I have been running D6 for a couple of years
It cleared up some notchy 2nd an 3rd gear problems. It what redline shows on there app and I believe its a little thicker than the stock fluid. It never gets super hot where I live pretty much . I went skiing when there was such a thing as snow in California with no problems. |
05-17-2015, 05:12 AM | #4 |
General
17365
Rep 18,765
I've only used the OE fluid in my E90's manual transmission. Just hit 282K last week. That said, I used Redline MTL in my E30's trans for most of it's life and it went to 290K (or farther); I sold the car. But that was with BMW's recommended change interval of 30,000 miles.
05-17-2015, 03:10 PM | #8 |
19
Rep 379
I have got redline ATF for about a year in my car. I am in baltimore and i haven't had no issues. Initially the fluid swap fixed the hard 2nd gear issue but overall i don't like the feeling of this oil that much. I will go back to OEM next winter.
********** 2008 BMW 335i TT******
05-17-2015, 03:42 PM | #9 |
533
Rep 2,872
I agree to an extent, I also don't feel like the oil changed a whole lot after the first couple hundred miles. The beginning was like butter, now it's slightly better than it was before. However, it's better than stock when it comes to real cold weather.
05-17-2015, 10:11 PM | #11 |
533
Rep 2,872
05-22-2015, 01:45 PM | #13 |
16
Rep 116
Put in Redline MTL today. Not sure what was in there before, most likely OEM fluid, but it was all black and nasty looking.
While at it, swapped drain and fill plugs for Dimple magnetic ones. Was only able to fit about quart and a quarter before it started to overflow. Must say, shifts are considerably smoother with the Redline fluid. |
05-22-2015, 04:15 PM | #14 | |
23
Rep 322
