Code P2C57 on E92 N55...interesting
05-16-2015, 04:27 PM | #1 |
340
Rep 1,744
I posted this in the N55 section too, but curious to see if anyone else can figure out what it means.
Someone posted this: Power management, closed-circuit current violation. The fault is recognized when the discharge from excessively high standby currents is higher than 1 Ah. Potential problem source(s): - Closed-circuit current too high Also, went to get my battery, alternator, and starter checked. Everything came out good. Battery said to be GOOD-RECHARGE. It's supposed to be rated at 720cca but mine was at 874cca. The battery meets or exceeds industry specifications, but is low on charge. Could it be that I installed and uninstalled the Cobb V3 and should have gotten a battery charger to charge it afterwards? If that's the case going to Target to get a Duracell battery charger for $50. Thanks! |
