Glazed tail lights... How to restore?
05-06-2015, 11:53 AM | #1 |
426
Rep 2,136
Hello guys,
I'm asking the pro detailers on here, how would you restore the look of this tail light? The plastic cover is getting all rough. BMW must have used two different quality plastics for the tail light cover on the trunk and the ones on the quarter panel... The plastic on the tail light on the quarter panel is still smooth and shiny, but the one on the trunk lid is getting all foggy and rough looking as you can see in these pics... I'm curious, does anyone else have this issue on their e92?
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch Last edited by Gizm0; 05-06-2015 at 12:03 PM.. |
05-06-2015, 12:01 PM | #2 |
142
Rep 726
The cheapest way that works well enough depending on how bad it is, use toothpaste (w/no flakes) just regular white toothpaste. Clean the headlights/tails and dry them, apply the toothpaste rub it with a soft cloth and then rinse off with water and dry them. IF it doesn't do the trick, then go to a store and get a headlight restorer.
2006 Bmw 325xi VMR V715/OE lip/Redlines/Zsp Springs
1999 Eclipse Spyder Gst 16g/264cams/550cc/255lph/corbeau seats/Comp Stage 4 Clutch/ECUflash etc... |
05-06-2015, 12:01 PM | #3 |
266
Rep 952
Start with a headlight cleaning compound, like Meguiar's PlastX. This would only remove fine scratches and improve clarity. But you should try the least abrasive solution first.
If that does not work, you'll need to try something more abrasive like a very high number (>1000) wet sand paper or rubbing compound. After using the more abrasive compound, you'll then need to make a second pass with a finer polishing compound. |
05-06-2015, 12:21 PM | #5 |
23
Rep 202
I would treat it the same as a headlight lens. As mentioned earlier, you want to start with the least abrasive solution. I'd start with a good coarse polishing compound such as Maguire's M105 with a corresponding pad on a buffer. Follow that up with M205 on a softer pad. If that doesn't cut it, 1000 grit wet/dry sandpaper up to 2000, then repeat the above process of polishing. Follow up with a good sealer/ wax applied on a frequent basis.
Plastx will work for a bit, but you eventually have to redo it, just like the tooth paste. The above process should keep them looking nice for a few years.
2011 BMW 335xi (e92) - Black Sapphire Metalic, Coral Red Interior, X-Drive, iDrive, Executive Package, M-Sports, Servotronic, Glacier Silver Trim
Mods - BMW Performance Black Kidney Grilles, OEM Oil Cooler Install |
05-06-2015, 12:23 PM | #6 |
215
Rep 1,818
if you do anything more aggressive than a simple polish compound, I'd recommend sealing them with a UV protectant clear coat, or the haze is going to come back faster and worse
05-06-2015, 12:35 PM | #7 |
426
Rep 2,136
Thanks guys... I'll try the rubbing compound + buffer first and if it isn't enough, i'll use some fine wet sandpaper...
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch |
05-06-2015, 12:36 PM | #8 |
23
Rep 202
If you can, pull the lights off the car to protect the paint and make them easier to work on. If that's not possible, make sure you put some painters tape around the lens.
05-06-2015, 12:39 PM | #9 |
426
Rep 2,136
Will do... I was already going to tape up around the light.
05-06-2015, 02:08 PM | #10 |
153
Rep 982
I'm guessing wet sanding would work as well.
2011 BMW 328i Space Grey|18" Avant Garde m359|Michelin Pilot Sport A/S2|Eibach Pro-Kit Springs|Koni FSD|M3 U+L Control Arms|Lux Angel Eyes|Stoptech|Hawk 5.0|aFe Race Pipes|BMW PE
