05-04-2015, 03:19 PM | #1 |
3105
Rep 7,032
Drives: 335xd Msport +
Xenon bulb upgrade anyone
was looking at Osram night breakers which are alleged to put up to 70% more light on the road with a whiter beam that's 20m longer.
Sounds tempting at about £70 or so per bulb as a relatively straight forward safety upgrade Anyone out there tried them or any general thoughts ???? Also any ideas roughly how much have people paid to have bulbs changed as I don't think you can/ should do it yourself - although I bet somebody somewhere has and lived to tell the tale |
05-04-2015, 03:21 PM | #2 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
05-04-2015, 03:24 PM | #3 |
General
6733
Rep 20,651
Bound to be someone that has, however with the 'dancing lights' not sure I would want a longer throw as may get flashed more or mess up how they interact with other motorists.
05-04-2015, 03:30 PM | #4 |
General
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
DTP1980 has them fitted, says they're noticeably better. The standard bulbs are the standard Philips or Osram bulb and then they both do a higher spec one.
I will replace mine with these upgraded ones but have decided to wait till autumn when the nights draw back in again. And the wife will kill me if I don't pause on the mods for a bit!
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
05-04-2015, 03:41 PM | #5 |
3105
Rep 7,032
Wouldn't have thought they would affect the warranty as its still a standard spec bulb
Can see the point about the adaptive headlights though but still might be worth a punt as having looked on you tube there seems to be a noticeable difference in light quality. Didn't have any issues when I upgraded and increased the height on my previous 3 which had halogens |
05-04-2015, 04:03 PM | #6 |
Fool
1857
Rep 3,542
I've used them before, there's no issue at all with adaptive, but I've found on the latest car that the headlights are aimed higher so I don't think I'd benefit much from the "upgrade". After reading a few weeks ago that the HIDs are under warranty, I don't think I'll bother now.
05-05-2015, 07:16 AM | #7 |
83
Rep 418
They are a significant improvement over oem (which are Phillips). Phillips do their own top end bulb of comparable performance for the same price. Ignore the fact the the lumens are all the same, it is misleading but I can't give a scientific reason why. These are much.
They draw the same wattage and are e marked so warranty problems should be unfounded. They work especially well with adaptives. The 'dark patch' is even clearer (seems darker) and in certain circumstances they work even better, switching off at safer points. Night driving confidence is much greater. Easy to fit too. 20 mins for none adaptive, 30 mins for adaptive. Care is needed regarding the locking tabs for the sealing 'door' into the back of the headlight unit. And they need 'bedding in'. The more you use them, the brighter they get. So far as value for money is concerned, these are on a par with LED, if not better, for a fraction of the price and I throughly recommend it. Also, buy from an approved retailer. There are cheap imitations everywhere. Just buy from Powerbulbs. Usually some discount around to ensure sub £150 for a pair. |
05-05-2015, 07:21 AM | #8 | |
1219
Rep 1,319
05-05-2015, 08:59 AM | #9 |
Fool
1857
Rep 3,542
05-05-2015, 09:03 AM | #10 | |
Beemer Heaven
462
Rep 2,941
Scott
05-05-2015, 09:17 AM | #11 |
83
Rep 418
As referred, they are like tamper tabs, and provide little or no 'lock'. I kept them prised back to prevent breaking them. So it doesn't look like mine have been opened.
05-05-2015, 02:44 PM | #14 | |
3105
Rep 7,032
Standard Xenons are good and definitely an improvement over halogens which I upgraded in my previous 3 As mods go seems a relatively cheap upgrade that would improve safety etc as I do a far bit of mileage on unlit roads. Would probably check with dealer re cost of changing bulbs before I tried to have a go myself to avoid any warranty issues. |
05-05-2015, 03:15 PM | #16 | |
3105
Rep 7,032
Got ACS springs, front splitter and rear diffuser fitted to my car all by my local BMW dealer all non BMW Not the cheapest but work is done to a decent standard and you know you can go back them Didn't know that about the bulbs though !!!! |
05-06-2015, 12:28 AM | #17 |
1779
Rep 4,518
Kal,
Link below, brace yourself though when read the price 100%+ mark up !!!! http://www.bmw.co.uk/en_GB/topics/ow...ryId=9890.html
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
05-06-2015, 01:45 PM | #18 | |
3105
Rep 7,032
That's just taking the mickey. About £120 or so from powerbulbs that's nearly 350% mark up. !!!!!! |
05-07-2015, 09:26 AM | #19 |
3105
Rep 7,032
Checked with BMW approx £57 a pair to fit only
About 20mins of labour |
05-07-2015, 10:19 AM | #20 |
1779
Rep 4,518
Kal,
£57 for BMW main dealer to fit only, based on you supplying the non OE bulbs ? Which dealer, as my local service dept wont touch customer supplied non OE parts...... BP
05-07-2015, 11:16 AM | #21 | |
3105
Rep 7,032
Sytners in Oldbury Found osram nightbreaker plus bulbs on e bay for £110 delivered or powerbulbs - safer bet probably for £150 after 20% discounted and hopefully in stock this week. |
05-07-2015, 12:06 PM | #22 |
General
6733
Rep 20,651
I find then a really good dealership, debating having them as my 'Local' service place.
