05-01-2015, 06:32 AM | #1 |
102
Rep 188
Will the M sport calipers fit on 345x32 rotors?
I am thinking about upgrading my calipers and was wondering if the calipers would fut the rotors I am running now. I want to get rid of the heavy steel calipers I have for now Also how is the performance of the sport/performance package? I would be upgrading to the 370 discs. Can they handle track use or should I be going aftermarket?
BMW 850 (BDS)
05-02-2015, 06:43 AM | #3 |
Rep 31
You may need to make up some 5mm spacers if using a 345mm disc as the the std size for the high power models is 340mm without the MSport brake package, which increases the HP models 340mm discs to 370mm.
You may find this link useful http://www.turnermotorsport.com/t-br...fferences.aspx |
05-02-2015, 10:41 AM | #5 |
3572
Rep 10,352
The calipers are same (M-Sport Line (fronts), M-Sport brake, M Performance Brake).
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
05-02-2015, 02:22 PM | #6 | |
102
Rep 188
What if I have aftermarket 32mm thick ones. Will the calipers fit over them?
BMW 850 (BDS)
