KW V1s on 11' 335i Xdrive Short Review
04-28-2015, 05:01 PM | #1 |
10
Rep 97
After many months of seeking advice from the E90 Post members I finally pulled the trigger on these exceptional coilovers for my daily driver - and couldn't be happier!
For any new XI owners still riding an OEM suspension...STOP! BMWs are NOT supposed to handle like this!!! Invest in a suspension upgrade ASAP!!! ANYTHING is better than the OEM for XI. My KWs have been on the car for about a week now and I'm truly surprised not only at the improved handling - which is amazing, but also how truly better the ride quality is overall. So much so, that even the run-craps feel better - (although PSS will be the replacements when the time comes). I know there are some varying opinions here about the best suspension options for the XIs, but the consensus with my research was that there would be no second thoughts or second guesses with the KW acquisition - and it was hard to find any criticisms anywhere about them. They were more money, but the suspension is such an integral part of the BMW experience, I viewed it as an investment both in the car and in my enjoyment of driving it. I was also wary of trying the spring-only route only to pay more later (as many members cautioned). In summary: the general ride quality increased exponentially; the cornering is noticeably and substantially more balanced and sharper; the steering control is more responsive; and at high-speeds 100-140km/h (80-90 mph) it is RIDICULOUSLY stable and confidence inspiring (ie: instant lane changes with barely a spec of body roll). Aesthetically, (which was a secondary/tertiary concern to me) it looks way slicker - going from almost a 2-2 1/2 finger gap (OEM) to 1 finger. I'm running stock 19s @ 225/255 and did have to remove my rear 15mm spacers to avoid rubbing, but I suppose that can be adjusted. I'm still not sure about the 'rake', so any suggestions would be appreciated. I have 18s for the winter and they should fit comfortably without any adjustments each season. Here's a pic after the install, and some before/after close-ups of the gaps. Last edited by ronmeister; 04-28-2015 at 06:03 PM.. |
04-28-2015, 07:54 PM | #3 |
179
Rep 430
How much did you lower? Did you do alignment after? Was it out of spec?
Doing the same very soon. Next week most likely. Really looking forward to it. Already have PSS installed |
04-28-2015, 09:23 PM | #4 |
82
Rep 604
Looks great! Coilovers are up next for me as well, debating between kW v1 and sonic tuning s3. The main reason for the sonics are they are cheaper and can also adjust dampening, kW are only height adjustable. On that note, do you feel the dampening on the kW are spot on? Would you prefer it softer or stiffer at any times?
Thanks for the review bud definitely helps out. |
04-29-2015, 07:08 AM | #6 |
309
Rep 1,733
Drives: 2003 M3
Looks great.
04-29-2015, 07:37 AM | #7 |
327
Rep 1,397
I have the exact same car as well and ibe been debating pretty hard about what to get. I think I finally decided I'm going to pull the trigger on these really soon.
04-29-2015, 11:24 AM | #8 |
10
Rep 97
I'm not sure precisely what drop was calculated by my installer on the threads, I can only say that it appears about 2 fingers less - in fact, I can barely get a flat ruler in there at present. The alignment is coming next week for sure.
04-29-2015, 11:31 AM | #9 | |
10
Rep 97
If I planned to track it more than 3-4 times a year (and if $ wasn't an issue) I'd probably consider the V2 and V3 for the adjustability but as a daily driver I truly doubt I'd ever tinker with it enough to make it worthwhile. I had the opportunity a while back to drive a ///M3 with EDC...it was awesome! |
04-29-2015, 11:43 AM | #10 |
Rep 184
Yeah, I went down the same road... gave KW V1 in approx. a month ago (front went down by some 30mm, rear dropped less - 20mm) and .... enjoyed ever since. Stiff, but not overly so. Sharp cornering now becoming a pleasure, not a must
Speaking of daily car - this truly is a recommendable chassis upgrade.
Daily:330ix 6MT - PBX, HR SportSprings, Koni Yellows, OZ Ultraleggera 18", PI+PE, CDV off, UUC sways, M235i SportBrake (front), Cquence rotors (rear), 3.64 diffs, LSD rear
Funcar: Z4 3.0i 6MT - HR SportSprings +sways, OZ Ultraleggera 19", 5.00 diff by Drexler, CDV off, Quaife LSD, M235i SportBrake (front), Cquence rotors (rear) |
04-29-2015, 12:22 PM | #11 |
37
Rep 504
Drives: BMW 335xi 2011
Nice review! Drove the car in winter with V1s and I was amazed with the handling ! Not planning to go back stock.
BMW 335 xdrive 2011 BSM
BMS Intake, ER CP, ER competition FMIC, N54tuning DP, COBB V2 stage 2+ aggressive, side marker delete, LUX V5, BMW PE, KW V1, Volk Racing CE28N Candy Red (SOLD), Advan Racing RS |
04-29-2015, 12:29 PM | #12 |
27
Rep 689
I've had the V1's on my 2011 for about 3 years, 3 of them have started leaking. I've decided to go with TCKline instead of throwing them back on once rebuilt. I'll put them up for sale once they fix them. I'm pretty disappointed they crapped out after such a short time!
04-29-2015, 01:27 PM | #13 | |
327
Rep 1,397
04-29-2015, 01:31 PM | #14 |
27
Rep 689
04-29-2015, 04:05 PM | #15 |
327
Rep 1,397
Ya but that could definitely lead to them not lasting long. I live in calgary so I'll be in snow too, but nothing I haven't done before by driving with coilovers in the winter.
04-29-2015, 04:47 PM | #16 |
35
Rep 1,068
That's what scared me and sold my v1 before even installing them. I need durability.. Got bilstein sports.. Guaranteed the v1 would have been more comfortable!
04-29-2015, 04:48 PM | #17 | |
///M
227
Rep 2,248
I've had my V1s for a year now and love them! Probably hands down the best mod I purchased for the car.
04-30-2015, 07:48 AM | #20 |
Rep 184
In my case (adaptive bixenons) they do NOT. I had to play with angle adjustement knob a bit (fortunately, its range is large enough)
04-30-2015, 10:00 AM | #21 | |
306
Rep 7,433
04-30-2015, 09:30 PM | #22 |
Rep 103
KW V1 was my first mod done to my car about a year ago and been great so far.. I just got the same set of 19 313 wheels.. i added 12mm spacers all around.. think couldve gone with 15mm in front but love the way it looks now..
2020 Tesla Model 3 "Stealth" Performance
*sold* 2011 335i xDrive e92 KW V1, JB4 Stage 2, BMS Intake, VRSF Chargepipe & Downpipe... |
