04-27-2015, 01:28 PM | #1 |
29
Rep 77
Auto Stop/Start function....please explain!
I've been driving a 2004 manual ZHP for 11 years and just bought a 2015 m235i 8sp so forgive me of the confusion/hatred for the stop/start function.
So I asked the girl that goes over the features of my car on how to turn off stop/start functionality after not liking it on a loaner car I drove a couple years ago. She said just press the button above the engine stop/start button. I could see on the feature on the display show a line thru it. Oh that doesn't seem to difficult....on to the next car feature. We leave the car. Then I get in my car to leave the dealership and get to a red light and the engine cuts out. I press the button she showed me and see the line thru the feature on the dash...it's turned off. Then I get another red light and it shuts off again.....why!!!! Then I get to a parking lot, press the P button, and press the engine stop/start button. Engine is off and stereo is still going. And I'm going thru some of GPS settings. At this point I don't know if my foot is still on the brake or not. But the car starts......why!!!! Thank god the car was in park. This stop/start is a dangerous feature IMO. I'll probably go to the dealer and get it disabled. Unless I get clear explanations on what the heck is happening. |
04-27-2015, 01:37 PM | #3 |
451
Rep 845
Couple of things. First, the best way to determine if the feature is OFF is if the light above the start/stop button is on. If it's lit up, the Auto on/off is disabled.
Second, just so you know, driving the car in sport (with engine/drivetrain turned into sport) or Sport + automatically disables auto on/off. Also, driving in ECO automatically enables auto on/off. Lastly, the car turned back on because it ran out of battery. If you have the radio, AC on when the car is auto "off", before it runs out of juice it will kick the engine back on to charge the battery. Hope this helps. FWIW I just keep it auto on/off turned off all the time. |
04-27-2015, 01:55 PM | #4 |
29
Rep 77
Thanks for replies so far.
When the girl was going over the car I told her I wanted the car in Sport mode. I think the car engine was off when she was going over the car....not sure though. After she went over everything I left the car for about 30 min. before leaving the lot. When I left the lot it was raining hard...never rains in San Diego...go figure. I just wanted to get the car home without getting it into an accident. So I didn't check if the car stayed in Sport mode when I left the dealership. But even if it wasn't, why after pressing button to disable it did it still cut off the engine at the following red lights. Regarding my second issue. My car was on the showroom floor and maybe, as you stated, the car started because the battery was low. I did notice the cars in the showroom floor had jumper cables under the front bumpers. Now I just need clarification why the disabling stop/start didn't seem to work. I'm back driving my ZHP now. |
04-27-2015, 02:02 PM | #5 |
1538
Rep 3,331
I think you are confusing 2 things.
When you look on the dash and see "Auto start stop" with a line through it - that does NOT mean the ASS is disabled. That means the car has CHOSEN on it's own power not to activate it. This is either due to a condition like aggressive braking, low battery power, AC or heat needing to stay on, etc. When you see the button above the start stop button, press it. The orange LED will light. This orange LED being ON means ASS is DISABLED permanently not just temporarily. The engine will not shut off. The EXCEPTION to this is if you put your car in Eco Pro. Putting the car in Eco Pro automatically re-enables ASS. If you accidentally hit Eco pro while scrolling through the modes even for a second you will need to hit the button again to turn it off. As long as you see that orange LED lit you should be fine.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
moltenfire42.50 |
04-27-2015, 02:57 PM | #6 |
29
Rep 77
Thanks Cyberdeamon.
"When you look on the dash and see "Auto start stop" with a line through it - that does NOT mean the ASS is disabled. That means the car has CHOSEN on it's own power not to activate it. This is either due to a condition like aggressive braking, low battery power, ...." I assumed when she pressed the button and I saw the line thru 'Auto start stop' that it was being disabled. Seems the line thru it was was probably because a low battery. I'll have to check the light the next time. I better leave work early and do some driving so the battery gets charged. Thanks for the info. |
04-15-2019, 06:52 PM | #7 |
Rep 5
Hey all, this feature has been annoying me lately as well. Your comments confirm my suspicions but I still can't figure out why the car chooses to disable ASS every time I stop. In the months I've owned it, it's not automatically turned off once (with the system activated). Is there anyway to verify what specific reason it's choosing not to turn off?
04-15-2019, 07:11 PM | #8 |
3074
Rep 5,577
I don't think the dealer will disable the START/STOP feature - it's probably related to emission and mpg and can't be disturbed by the dealer.
On my 235 the tachometer needle has two OFF settings, When the cars START/STOP feature is engaged the tach needle drops to 'READY' when the car ignition is turned off the tach needle drops to 'OFF'. I do occasionally use ECOPRO Mode and STOP/START and my fuel consumption takes a significant drop. |
04-16-2019, 01:37 PM | #9 |
16
Rep 18
I drive a 6MT, so car turns back on once you push the clutch in again.
I assume the car starts again once you let go of the brake? Atleast from my experience from other cars with similar feature... Or do you have to manually press the start button? |
04-16-2019, 05:58 PM | #10 |
221
Rep 314
I was a little confused about this function when I took delivery of my car as well, but have since just kept ASS off at all times.
Any way to just code out/disable this function altogether? Every once in a while it seems to get turned back on. Maybe I'm just fat fingering the starter button occasionally. |
04-16-2019, 06:08 PM | #11 | |
272
Rep 823
04-16-2019, 07:37 PM | #12 | |
403
Rep 744
Drives: 2017 M240i Glacier Silver
- You must be in "D", not "S" or "M". - Make sure the "A Off" button is not on (the LED indicator light indicates that "A Off" is enabled, the indicator light needs to be off for the auto stop system to work).
Fun Cars (daily drivers) 2001-2016: 2001 Honda Prelude | 2016 - present: 2017 M240xi Glacier Silver Coupe
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible |
04-17-2019, 12:52 PM | #13 |
630
Rep 1,227
I drive in Sport when I'm by myself and Comfort when having passengers. Despite driving in Comfort a good amount of the time I don't think I've had the ASS turn the engine off for me a single time in the 18 months I've had the car. When I picked it up in Europe the first thing I did was press the ASS OFF button above the Start/Stop button. To do this day I have not touched it.
04-17-2019, 01:49 PM | #14 |
255
Rep 326
Bimmercode is a good investment in reliably customizing these complex creatures, to the next deeper level.
I coded off the ASS function, the fake exhaust noises and made some lighting preferences, all fairly easily. I did not diddle with every last option available through the Bimmercode app, as it can get over obsessive. But for those few things, totally worth it.
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also" |
04-17-2019, 02:00 PM | #15 | |
4654
Rep 6,031
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
04-19-2019, 05:13 AM | #17 | ||
221
Rep 314
05-01-2019, 09:03 PM | #19 | |
Rep 5
I thought it might have been the cooler temperatures outside the last couple of months but even at 70 today it still didn't shut off. I'm hoping something isn't actually wrong with the system. |
05-02-2019, 08:05 PM | #20 | |
114
Rep 87
If you're in eco pro mode, it will also have a more obvious blue gear stick indicator. I notice under 50-60 degree conditions it usually takes about 3 minutes of driving until it will auto stop. |
05-02-2019, 08:07 PM | #21 | |
59
Rep 205
05-02-2019, 10:03 PM | #22 |
Rep 5
Thank you for the information! The car does not rev match like I've seen in other 2 series before (or its not working). I have seen the blue shifter in eco mode but never knew what it was indicating.
This might be too technical of a request, but is there anyway to see if it was coded off or see what condition isn't being met through ODBC? |
