04-21-2015, 12:28 PM | #1 |
78
Rep 1,353
Adaptive M suspension and H&R sport springs
Just a quick question. I know about the shocks' lifespan being shortened by lowering spring, but his is my first Adaptive suspension. Will I be messing the system up to the point that it might throw a code if I drop it with just the H&R Sport springs?
04-21-2015, 03:13 PM | #3 |
Rep 34
Dinan has the "Dinan Shockware" that pairs with your Adaptive Suspension and is meant to work with Dinan's performance lowering spring set. If you call Dinan, they may be able to give you info on whether it adds additional wear to the shocks as they do pretty extensive testing for their products. Just something to check out if you haven't already.
04-21-2015, 05:46 PM | #4 | |
78
Rep 1,353
04-22-2015, 11:18 AM | #7 |
538
Rep 1,201
You stated the reason why I am not doing a lowering spring on my F80 that has adaptive suspension, for fear that the shocks would be worn out prematurely and I will have to pay a few thousand dollars to replace the expensive electronic shocks. If I just had passive suspension, I'd put on a good coilover setup on day 1.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
04-22-2015, 05:06 PM | #9 |
78
Rep 1,353
Can you post or PM me a pix of your car. I just want to see how low H&R sport spring can go on F32. I don't want a stanced profile. Just wanna eliminate or at least lessen the wheel gap. Thanks in advance!
04-23-2015, 02:36 AM | #10 |
1779
Rep 4,516
Box,
Sorry - mines and F20 M135i - photo in my sig shows the H&R stance. Perfect IMHO BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
04-23-2015, 11:32 AM | #12 |
1779
Rep 4,516
Thanks. OEM adaptive dampers, H&R sport springs 1" drop all round. H&R sway bars too + quaife LSD + F8x front lower control arms. Car is v nimble and yet still rides well.
04-23-2015, 11:48 AM | #14 |
127
Rep 764
04-23-2015, 01:16 PM | #16 |
BimmerPost Supporting Vendor
24199
Rep 190,807
It wont throw a code but as mentioned as long as you are not worried about a shorten lifespan, you are good to go.
04-23-2015, 02:12 PM | #17 |
18
Rep 101
If we decide to go for it but it ruins the system and the warranty is still valid, would it be covered or would I have to put the OEM springs back then go to dealer?
04-28-2015, 08:24 AM | #20 |
1779
Rep 4,516
depending which workshop you go to - anywhere from 2-4hrs labour time. Alignment would then be extra.
04-28-2015, 08:37 AM | #21 |
18
Rep 101
So basically about 300$ around that + Alignment.
I called the BMW dealer for the Dinan springs since in Montreal they are the authorized reseller. They were charging 1,130$ for installation!! |
