2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Lease turn in with Michelin PSS
      04-15-2015, 10:26 AM   #1
ineedae46m3
ineedae46m3's Avatar
105
Drives: F80 M3
Do you need to turn the car in with that exact tire? If not what tire is equivalent? Any non run flat tire with the same speed rating?
Thanks!
2018 F80 M3 - 6MT - Alpine - Sakhir
2015 F22 M235i - 6MT - Estoril - Oyster - SOLD
2007 E90 335i - 6MT - Crimson - Terra - SOLD
      04-15-2015, 11:17 AM   #2
hyperzulu
hyperzulu's Avatar
701
Drives: 2015 M235i
Well technically it has to be a tire approved by BMW, which generally means OEM spec, size and speed rating inclusive. Sometimes they change OEM tires or use two different brands and you can choose one or the other. The tires also have to have 4/32 tread left, but again this is up to the dealer... some may charge you and some don't even really check.
My last car had runflats, I bought some used ones and had them mounted for much cheaper than a full set.
      04-15-2015, 12:07 PM   #3
338FREAK
10
Drives: Midnight Blue 2015 BMW 228XI
I'm sorry but I have to bust out the rounding police ... 4/32.... I'd go with 1/8
      04-15-2015, 12:30 PM   #4
ineedae46m3
105
Drives: F80 M3
It just is vague with non RFT because there are many choices in the M235i size.
      04-15-2015, 01:44 PM   #5
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
As long as the tires are the same size, have enough tread left, and match the speed rating you should be totally fine.
I just turned my last car in with worn out run flats that had sidewall damage and the dealer just took the car no questions asked since it was the end of the quarter and they wanted to hit the quota. They actually assessed the car with my snow tires and aftermarket rims and were about to overlook it until I brought up that I still had the OEM wheels. That's certainly the exception though and not the rule.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
2addicts
