BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Oil change
      04-14-2015, 09:25 AM   #1
Echo335
18
Drives: 2009 E92 335i
Oil change
When's a good time to change the oil on my 2009 E92 335i? Does every 5k miles sound about right? Or is that too soon? I know these N54s run best when they are well maintained.
Thanks!
      04-14-2015, 09:30 AM   #2
BavarianMWfan
12
Drives: -
5k Sounds about right. If you mainly travel on the freeway, you can push it to 7k.
Appreciate 2
      04-14-2015, 09:31 AM   #3
Douche
466
Drives: Car
I would follow this to heart.
      04-14-2015, 10:01 AM   #4
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Change mine every 7.5K
Back when I was under Maintenance Plan - oil changes were free every 15K - I still changed it myself in between...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      04-14-2015, 10:04 AM   #5
1chanc3
148
Drives: 2010 e92 335i
I've been doing 7k since 50k miles (should have done that interval sooner. oh well).
2010 335i Coupe- Monaco Blue Metallic
      04-14-2015, 10:35 AM   #6
335NJ
533
Drives: 2008 335i 6MT E90
I do every 5k, however according to my last Blackstone Labs report, I could stretch it out to 7-8k. I just do it at 5k regardless though.
      04-14-2015, 10:36 AM   #7
BashShah
298
Drives: 2012 335i Sedan
Personally I think anywhere between 5 and 10k miles is OK.
      04-14-2015, 10:53 AM   #8
monkeybingo
Mongolia
59
Drives: 121
I just went by factory recommendation 1yr/10k since I had no plans to keep long term
      04-14-2015, 11:04 AM   #9
CantCatchMe
Romania
340
Drives: 2012 335i xdrive msport(E92)
5-6.5k is normally my intervals. I do 65% driving on the hwy and 35% city.
      04-14-2015, 05:26 PM   #10
Agentphish
129
Drives: '08 328i
Do yourself a favor and get one of these http://www.qwikvalve.com
5-7K is what I've heard most from pros at indie shops and on these boards and what I've done for the last 2 years since owning my N52.
According to the indies I've spoken to biggest problem is that the filters start to wear out if you go much past that. They (and many of us here) think that 15K is insane for the filter, but that the oil is probably fine.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White
      04-14-2015, 05:56 PM   #11
ilicboris
ilicboris's Avatar
77
Drives: 2009 E90 335xi
5-7k is what I usually go by. I wouldn't feel comfortable stretching it past that.
      04-14-2015, 06:23 PM   #12
Miller335
291
Drives: 2007 E92
I'd do 5K.
Tons of stories of people running leaky injectors without really knowing it and getting more than average fuel diluting the oil causing internal engine issues.
I do 5K just to be on the safe side.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
      04-14-2015, 06:34 PM   #13
Gizm0
Gizm0's Avatar
426
Drives: 08 e92 335i 6mt
Every 5k, unless u run e85 often in which case every 3k would be safer...
      04-14-2015, 09:06 PM   #14
drewnel22
drewnel22's Avatar
141
Drives: 2016 Subaru WRX
7.5k is perfectly fine. You don't need to go down to 5k like a lot of people here unless you only drive it a mile or 2 at a time and it never warms up.
      04-14-2015, 10:23 PM   #15
e92_enthusiast_1
e92_enthusiast_1's Avatar
35
Drives: '10 AW/CR e92 6mt 335i
2010 BMW 335i  [0.00]
Oh really? I didnt realize, even if you just blend 30%?
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
      04-14-2015, 10:48 PM   #16
bender rodriguez
149
Drives: Audi
When the car computer says it needs to be changed
      04-14-2015, 11:32 PM   #17
thomas88162
19
Drives: E92 328i
Now this is advice. A lot of time and money goes into developing a proper algorithm to model the oil's wear based on engine usage. These oil life meters are very accurate systems. Asking about oil change intervals really just brings out opinions. There is nothing wrong with sticking by what you know, but you are guaranteed to get several conflicting answers by starting any form of oil thread.
      04-14-2015, 11:47 PM   #18
1chanc3
148
So 15k miles? yea right!!!
They only tell you 15k because they, BMW, don't want do more oil changes if your car is still manufacturer warranty/service. Saves them money and time.
And once your car is past the 50k warranty, they can give a shit about what happens to your car, and that is when our cars start becoming more fragile.
      04-15-2015, 01:28 AM   #19
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
481
Drives: 06 330i 6MT
BMW changed the service interval to 10k down from 15k for 2014 model year cars, even though they use some of the same engines as older models. So even BMW is kind of admitting 15k is too long.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      04-15-2015, 05:36 AM   #20
Swish
52
Drives: 2011 335i Sport
That valve is sweet!
I hated changing my own oil, but this thing could make me change my mind...and save me a lot of $.
      04-15-2015, 08:42 AM   #21
thomas88162
19
Drives: E92 328i
For the record, I never directly said follow 15k oil change intervals. I said follow the engine oil life monitoring system's wear curve. If you don't like 15k changes, change it every 50% of oil life or whatever floats your boat. The oil monitoring system is very accurate in terms of how you are wearing on your oil.
      04-15-2015, 09:42 AM   #22
1chanc3
148
To be honest, I've never even heard of this oil monitoring system. My buddy drove his 2009 328i to 21k miles without this "oil monitoring system" thing going off. 21k miles of high rev driving!!! Even his SA was surprised and impressed.
I had to advise him to take his car into the shop to get his oil changed....
So no, I don't want to trust this "oil monitoring system" because it might be too late when it finally chimes.
I'd rather be more proactive than reactive, especially since I drive 60 miles a day to/from work.
