Engine Fault 2A2E and 2A2F
04-09-2015, 07:16 PM | #1 |
46
Rep 177
Drives: E90
I just got a check engine light with 2A2E and 2A2F (Mixture Control and Mixture Control 2) faults. Anyone know what this is and what I should check or replace?
04-12-2015, 11:08 PM | #2 | |
46
Rep 177
Drives: E90
04-12-2015, 11:11 PM | #3 |
298
Rep 2,015
05-26-2015, 08:21 PM | #4 |
46
Rep 177
Drives: E90
MAF sensor
I don't think it's rotted vacuum . BT scan shows mixture control and mixture control 2 (short circuit or signal interruption). Do you guys think it's a MAF sensor fault?
06-02-2015, 10:33 PM | #5 |
46
Rep 177
Drives: E90
bump
06-02-2015, 11:26 PM | #6 |
Curmudgeon and Pedant
690
Rep 3,489
The referenced thread is all the info we have. You need to buy some time from someone who knows these engines to run through a trouble-shooting fault tree.
Still most likely to be a bad vacuum line somewhere. |
06-03-2015, 01:10 PM | #7 |
46
Rep 177
Drives: E90
I recently changed my air filter. I wonder if it's a loose air filter hose or housing connection ?? :
If not , how can I visually inspect vacuums lines? I assume it's s hose connected to fuel pump? Any direction would be appreciated. |
06-03-2015, 04:31 PM | #8 | |
690
Rep 3,489
The vacuum is essentially downstream of the MAF, including all the various little hoses running into the manifold. Look for cracked rubber, hoses off their nipples, etc. |
06-07-2015, 02:37 PM | #9 |
46
Rep 177
Drives: E90
I drove the car hard over the weekend over long stretched roads and highways . My car normally sees city roads . After an hour the hard Check engine light disappeared but I still smell burnt vapours smells. Not sure if it was a problem with my purge valves being opened. I cleared the fault with my BT tool and it's been a day and so far so good except for burnt vapour smell . Anyone knows what this could be ??
Update: The mixture fault came back again with a CEL. May need to find an Indy. |
06-29-2015, 11:54 AM | #10 |
1622
Rep 3,402
I have an 06 330i with 204,000 miles and have struggled with these fault codes on and off over the past 60,000 miles. I brought it to a good independent who changed the 02 sensors and that seemed to work for a while and then probably 10k later it popped up again. Because it was easy to do I changed the MAF and reset the codes and it was good for another 10-15k. Since then I have had it pop up occasionally, usually when I change the air filter it will go away for about 10k or so but recently I have had these codes pop up every 50-100 miles. I am going to break down and have a professional look at it. The car isn't worth much at this point but it is in good shape, runs well and I know exactly what I have so I want to pass it on to my daughter for her first car until she goes off to college. I will post what the mechanic has to say when I bring it in later in July. At this point I have a company car so this car only gets driven a few thousand miles a year.
07-01-2015, 10:57 PM | #11 |
46
Rep 177
Drives: E90
Brought the car in to Darren at DC Motorwerx. He diagnosed and fixed the problem promptly. It was a vacuum line that was not secured. He was able to re-secure it and the car drives great! Solved the rough idling issue and the mixture control faults.
Also was able to find the source of a awful nasty burnt smell. It was a melted black garbage bag melted on to the chassis. |
