The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > BMWhat Problems
      03-29-2015, 11:46 AM   #1
335dwanted
22
Drives: 2009 335d
BMWhat Problems
I have both the BMWhat app and the BT OBDII Adapter and they have worked fine since purchase until this morning. I was able to check for faults and successfully reset a couple of minor faults this morning but when I attempted to check Parameters the app advised that Parameters could not be read by my OBDII adapter. I have never had this problem before.
I did uninstall the app and re-install but no luck (I am running android).
I have an email out to the programmer so we will see what they respond with.
I was curious if anyone else has had similar issues with BMWhat? Perhaps a recent software update? While I use Torque daily, I only infrequently use BMWhat and don't think I have used that app for a month or so and I can only point to that rather large time window to suggest the onset of my problems.
      03-29-2015, 12:35 PM   #2
Persian Whisperjet
Kind of a Big Deal
167
Drives: 2011 335d
I only mention this because it threw me for a loop when I changed phones, but are you sure the BT adapter is still paired/added to your android?
      03-29-2015, 01:25 PM   #3
taibanl
taibanl's Avatar
281
Drives: BMW
When I did the last update, my adapter would only fully connect with the alternative method
      03-29-2015, 06:38 PM   #4
335dwanted
22
Drives: 2009 335d
Yes, it sees the BT adapter and connects; I can check for faults under the Diagnosis menu.
      03-29-2015, 06:39 PM   #5
335dwanted
22
Drives: 2009 335d
Hmmm.... I will have to look into this "alternative method" you speak of when I get in the car next time.
      03-29-2015, 10:20 PM   #6
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
I have checked mine today and parameters work after the update.
      04-03-2015, 10:20 AM   #7
335dwanted
22
Drives: 2009 335d
Just an update - Fired up BMWhat a couple of days ago and Parameters was working fine again. I have a sneaky suspicion that when I detected the problem that I neglected to start the engine (just had the ignition on but unstarted).
Note that it was not the absence of live data that suggested a problem but rather the message from the app indicating that the BT adapter did not support Parameters.
At any rate, all is good again.
      04-03-2015, 11:03 AM   #8
Big_Daddy_38
Drives: 2011 335d
2011 BMW 335d  [0.00]
I run BMWhat with their wifi adapter on iOS. To monitor parameters, I always need to reset the phone and unplug/replug the adapter.
The other issue I see is that I can't monitor or log parameters for a long period of time (<5-15min).
Anybody else experienced/fixed these issues?
While I run via wifi, it acts the same with Bluetooth on or off.
