BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Anyone using dash command ?
      03-16-2015, 01:43 PM   #1
Ben1987
Drives: 320d
I've just downloaded dash command app one iPhone using wifi odb wifi reader and a lot of apps functions aren't working or say n/a cant get it to show
.boost pressure
.torque
.coolant temp
And a few others is anyone else using this is it just a case I've not set it up right
Any info would be great ! I've googled it but it's like reading a different language lol
Cheers Ben
      03-16-2015, 04:38 PM   #2
marklemac
marklemac's Avatar
27
Drives: 335d Coupe
I'm using it Ben. I just added my car, verified the PID's and all the parameters work fine.
// Diesel Power //09 335d//
      03-16-2015, 04:44 PM   #3
Ben1987
Drives: 320d
How did you verify the pids I've not done that I dont think it shows me mph and revs but not a lot else csnt see anything on fuel consumption did you fill in any of the advanced settings ?
Thanks
      03-17-2015, 02:41 AM   #4
marklemac
marklemac's Avatar
27
Drives: 335d Coupe
When it's all plugged in and connected, you just add the car to the list and there is a 'verify pid' button. That's all I did Ben.
I haven't touched the advanced area, apart from weight.
      03-17-2015, 09:58 AM   #5
Ben1987
Drives: 320d
Maybe my car doesn't have some of the pids then which is annoying as it's not showing me anything I don't already know !
      03-17-2015, 02:54 PM   #6
marknjayne
23
Drives: 335d
mine works and reads fine,you do need to verify though
      03-17-2015, 03:11 PM   #7
myboris
Drives: E92 335i SE
Do you just need an adaptor for this to work? Do you need I drive?
      03-17-2015, 04:20 PM   #8
Reece
53
Drives: e90 lci 330d
Anyone know how accurate the temps etc are?
E90 lci 330d, alpine white, pro nav, adaptive xenons, heated electric leather, folding mirrors, alpine retrofit kit with L7 subs, performance grilles, 40w led angel eye bulbs
      03-17-2015, 04:36 PM   #9
Fantastic
Drives: F31 Xdrive
I've downloaded it, just waiting for my wifi obd thingy to arrive.
i read somewhere that somebody connected their iPad and iPhone to it and got different readings so maybe take temps etc with a pinch of salt.
Doesn't bmwhat app have pretty much the same on it though! Albeit a lot more expensive.
      03-17-2015, 04:56 PM   #10
Ben1987
Drives: 320d
Well I've had a play with it tonight on the iPad and found a section that shows supported pids so it's showing more now eg voltage a frw other bits but it says boost is supported but when I run it in dashboard it says n/a on the boost gauge which is annoying me ! Mines a 2006 320d has anyone else managed to get this working !
      03-17-2015, 04:59 PM   #11
Ben1987
Drives: 320d
You just need to buy a wifi odb reader if your using Apple and download the app if your using android I think you need a Bluetooth odb reader.
