BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > High Def radio and Bluetooth tethering with CIC and combox retrofit
      03-16-2015, 01:54 AM   #1
phubar
86
Drives: 335 Vert
Hi all,
I'm having issues getting the HD radio to work with my retrofit, my CIC retrofit unit is both HD and Sirius capable, I was able to get the "Satellite" option in the CIC but i have no way to test if it actually works, the HD option is available under the options menu but when selected it doesn't actually check the box for it and it goes back to the "Tuner" menu unchanged. No HD stations are available.
I retrofitted both CIC and Combox to my E93, everything is working good, except Im not able to get bt tethering working for the Live Browser.
Also I would like to change the Combox name displayed when setting up the bluetooth, right now it shows the last 4 digits for the VIN of the car it came out off. I coded the VIN via ssd file but its still showing the same thing.
I would greatly appreciate any help you guys can provide and would be wiling to donate some $$ via paypal to anybody that can help me figure out what the problem is.
Here is my FA and also attached SSD and current CIC TRC. Thanks again!
Code:
E93_#0911&LCD1%0475$1CA$249$255$2C6$2VB$319$430$431$441$459$481$488$494$4AD$4NA$4UT$502$520$521$522$524$534$544$563$5GA$609$614$620$644$645$653$655$677$698$6AA$6AB$6AL$6FL$6NF$6NR$6UH$6VC$704$818$823$840$845$850$853$925$9AA*WL73+TELD-A090
File Type: txt SSD.TXT (296 Bytes, 92 views)
