F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M Adaptive Sus & MPE Springs
proTUNING Freaks
      03-10-2015, 11:43 AM   #1
VenomUK
17
Drives: 428i M Sport
The website isn't clear if this can be done or if another spring type is needed?
I've got the M adaptive suspension and wanted to add the MPE lowering springs but can't be sure if the combo is compatible?
      03-10-2015, 04:52 PM   #2
bmrm396
640
Drives: 2018 F80 M3cs
you technically CAN do it that way but its not the preferred application and it prolly wont handle that well - the proper way to update to MPE is to buy the whole kit (version compatible for adap sus) http://www.getbmwparts.com/partlocat...75&startrow=26
Formerly addicted to e46fanatics
Formerly addicted to e90post
      03-11-2015, 03:42 PM   #3
jazza
jazza's Avatar
301
Drives: F32 428i
(version compatible for adap sus) ??? I don't understand
      03-11-2015, 05:27 PM   #4
bmrm396
640
sorry, what i meant was if you scroll down that page and see the MPE (item# 33502320981) - youll see an option for the package if your upgrading from standard suspension OR if your upgrading from msport/sport suspension
the MPE kit does away with the adaptive parts all together, no matter what you upgrade from, it is not meant to be used in conjunction with adaptive parts at all
... maybe that confused you more but the point is you cant pick and choose parts, its either the whole kit or not. And if you do upgrade to MPE you loose the adaptive ability in your susp
      03-13-2015, 02:44 PM   #5
axphilipxa
Drives: bmw 435xi
hey guys, i also had a question, i have a 428 xi coupe and I'm guessing i have the standard suspension, and what if i wanted to put in the sport suspension, is that possible with the all wheel drive , would i have any problems, can someone help me and explain this
      03-13-2015, 04:28 PM   #6
verheizer
Drives: 435i
@VenomUK
Springs and dampers always have to be tuned for each other.. But since the M adaptive dampers in sport mode let the car be a little bit overdamped, my guess is that this combination will work rather well.
f30post
