N54 OEM Engine Part out (strip) - Almost everything available
03-06-2015, 01:41 AM | #1 |
126
Rep 3,099
So life's gotten in the way for now, everything's up for sale 'til i get back on my feet The only parts not available are the Chargepipe and Rods.. I believe i still have the factory DV's but possibly not. Prices negotiable depending on what. Buying multiple items (especially if they usually go together) too. 50,000km/31k miles~. Turbos+lines RHD 335. Next to no play, probably needs new seals. $500 oil filter housing/thermostat housing.. $250? can maybe include oil cooler+lines Intake Manifold/Throttle body - $250/$100, $310 together Pistons x 6 $280 Cylinder Head, can include valves/springs/retainers (some locks missing..) $1250 Cams/VANOS stuff - $350 MSD81 DME, matching CAS, keyfob, dash cluster (bonus key fob dock thing) $1000 Oil pump (inc chain guide, or not)+pickup tube $100 Block w/crank, bedplate, squirters, vacuum pump - No scoring, good cross-hatch, everything spins freely by hand - $1500 6MT transmission GS6-53BZ/DZ, can't remember mileage i think it was 30,000km? it all spins freely zero bad noises, but would get it checked out/cleaned up. $1750 Will add pics in a while, gotta upload to imgur again loads of other parts no pics yet (just ask if you want) full engine wiring loom (labelled) $200 downpipes $350 valve cover $200 injectors x 6 $50/piece (or i'll keep them for our other car at 100k km, they're bound to go eventually) engine mount brackets (2) (the block parts not the rubber parts) $100 Alternator $250 A/C comp $250 PS pump + reservoir $150 Oil Pan $200 Various sensors, solenoids, brackets etc. $??? Air Intake Box w/filter $150 air intake pipes (box>turbo) $100 ($200 box+pipes) Brand new OEM non 135i rear brake calipers (R+L) inc new pads $150 EA, $250 pair Used OEM non 135i (130) rear brake calipers (R+L) no pads $75ea Used OEM non 135i (130) front brake calipers (R+L) no pads $75ea Used rear drivers side (LHD that is) rear wheel carrier, no hub/bearing $150 Used E39 E53 E65 E66 E67 E83 interior mirror $50 Used (30,000km~) BC racing coilovers, one clunky from almost new that doesn't effect performance $800 |
03-06-2015, 03:24 AM | #2 |
Storm Trooper
Rep 174
Got a vanos solenoid?, do you have m control arms?
|Sedan|M2Bumper|3"Exh|MMPStage3s|Inlets|Outlets|BQ 93tune|Custom OCC|7" WBFMIC|
03-06-2015, 06:43 AM | #4 | |
126
Rep 3,099
I DO also have non-m arms, m-sport suspension with 50-55k miles though |
03-06-2015, 06:43 AM | #5 | |
126
Rep 3,099
Zero clue if anything was replaced after new. Safer to assume it's all original. All the oil that came out of the engine seemed pretty fresh, zero gunk anywhere |
03-06-2015, 10:32 AM | #8 |
Storm Trooper
Rep 174
I'll take the solenoids then. How much?
03-13-2015, 11:31 PM | #11 | |
126
Rep 3,099
ALSO if anyone wants to buy all the big bits (or everything inc accessories), i'll do them all at a much cheaper price |
03-14-2015, 12:06 PM | #13 |
321
Rep 710
Drives: 23 M3 Competition
14 F30 N55 AWD SpeedTech EFR-8374, E70 MHD, Motive tuned
23 M3 Competition - Stock |
05-30-2015, 06:03 AM | #14 |
126
Rep 3,099
whoops forgot about this...
at the moment i'd actually rather sell the lot (at a total much lower than listed) or keep it for when i get around to rebuilding. |
05-30-2015, 12:22 PM | #17 |
Rep 65
intakebox
05-30-2015, 12:25 PM | #18 |
Rep 197
05-30-2015, 09:38 PM | #19 |
117
Rep 622
Pm me a price for the oil cooler with mounting brackets and lines, no need for the thermostat and filter housing as I already have one picked up
Thanks! |
06-10-2015, 01:21 AM | #22 |
Rep 59
Drives: e92 coupe
Are you selling the diff? And what is the production date of your car?
