BMWHAT Oil Level in mm?
03-05-2015, 05:02 PM | #1 |
135
Rep 126
Drives: 2020 M2C HS
Hello,
My oil sensor is not working right so I am using the app bmwhat with an bt obd adapter to check the oil level but it is given in (mm) which is very weird, any one has any idea on what the level should be at in mm in an e90 328? Also the sensor works very weird, it shows me max level all the time even when I don't have oil. Any ideas? Thank you guys |
03-05-2015, 05:26 PM | #2 |
No 55mph
1622
Rep 8,476
To answer your questions:
> For the units:
As far as the sensor goes, it's obviously fubar & needs replaced. BMWhat will only read/display what the sensor puts out. So if the sensor is broke & putting out garbage - that's what the BMWhat will display...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
03-05-2015, 05:51 PM | #3 | |
135
Rep 126
Drives: 2020 M2C HS
The sensor of the car always shows max but the readings from the bmwhat app changes if a drain some oil or I put like .59 or .88mm. I don't know how to interpret that lol Thanks for your help |
03-05-2015, 06:08 PM | #4 |
No 55mph
1622
Rep 8,476
Funny, cause my BMWhat displays Oil Level in % Percentage, not inches or mm
03-05-2015, 06:13 PM | #5 |
135
Rep 126
Drives: 2020 M2C HS
03-05-2015, 06:15 PM | #6 |
No 55mph
1622
Rep 8,476
Android
03-05-2015, 06:27 PM | #7 |
135
Rep 126
Drives: 2020 M2C HS
03-06-2015, 05:43 AM | #8 |
General
17361
Rep 18,756
Well if you think the oil level sensor is not working, then going through the OBD II port to read it instead of the gauge cluster or idrive wouldn't work either since there is only one oil level sensor in the engine.
The sensor takes over five minutes to get a reading and then reports updates every 20 minutes after that. Also, the engine has to reach several parameters to get a correct reading. And after an oil change the sensor will read the old level until it changes once the system updates.
Tags |
bmwhat oil level mm |
