03-02-2015, 09:46 AM | #1 |
52
Rep 43
M Performance Brake Pedal Travel and Feel
I recently had a dealer installed m performance brake. There is definitely more pedal travel than the original brakes and less grab. Read through the previous posts and found that the coding is necessary after the installation so back at the dealer again. It still feels soft and hard to brake even after the coding.
Not sure if bleeding it once more will help or should I start looking into stainless steel brake lines. Seems like some folks here had a success with it. Any other route I should look into? Don't know if there's a proper bleeding procedure for it as well. |
03-02-2015, 11:30 AM | #2 | |
3576
Rep 10,355
03-03-2015, 05:26 PM | #3 |
pew pew
166
Rep 6,781
Try bleeding it again. We had the M Performance brakes installed and there was no noticeable change in pedal feel. We did have the car reprogrammed but I can't imagine that has any effect on the pedal feel. It's a typical hydraulic brake system and bad pedal feel would only be a function of air in the system (or problems with the master cylinder, which is not changed with the brake retrofit).
CSL replicas are now CSL counterfeits. Jesus saves, like Valentine1.
03-04-2015, 11:32 AM | #5 |
pew pew
166
Rep 6,781
Honestly, I don't know if there's a specific bleed procedure. I've always just bled my brakes with a power bleeder. Never had a problem on any of my other 3ers. On my E36 when I suspected I had air in the ABS module I was able to activate the actuators by jumping a relay. I'd imagine there's a way to do that on the F3x as well, but probably wouldn't be necessary. A regular bleed probably works here.
03-07-2015, 07:26 AM | #6 |
52
Rep 43
Had the dealer bleed it again. The pedal felt a little better. I'm starting to wonder if it's the pad. I saw a previous post where a gentleman mentioned about m sport version (I have a euro version) euro compound pads bite better. Will see if stainless steel brake line will help.
03-07-2015, 09:22 AM | #7 | |
3576
Rep 10,355
I have your pads (M-Sport Line) and braking improved at about 500 miles. Be forewarned the euro pads from the M-Sport Brake Kit will dust like no tomorrow. |
03-07-2015, 10:09 AM | #8 |
52
Rep 43
Initially the car came with regular brake and I agreed that after 500 miles it bites good.
Does that mean I can use the m sport brake euro pads with my m performance brake? I don't mind the dust. |
