M3 suspension on E90 328i
02-11-2015, 12:58 AM | #1 |
10
Rep 64
Sup guys,
I have a 07 328i sedan that I want to do some suspension work on. I plan on getting coils and a few other things, but right now am more worried about which M3 pieces to install in the rear end. My car has a gasket leak, so the subframe is going to be dropped. While the subframe is dropped what can I install besides the M3 subframe bushings? Thanks |
02-11-2015, 07:41 AM | #2 |
Diamond Geezer
214
Rep 2,385
Drives: Jet Black 2007 328i Saloon
This is a little unclear. You have a gasket leak where? Are they dropping your front subframe or rear subframe?
If rear, I think the only thing that could be done to take advantage of the subframe drop in addition to m3 subframe bushings is rear sway. From what I've read you might want to explore / explain what you are trying to accomplish before going there (rear sway). |
