02-10-2015, 01:39 PM | #1 |
76
Rep 389
Windshield Washer Warning Light
I'm getting a washer fluid warning, even though I have filled it to the top.
Is anyone having this problem? I have coded the headlight washer off, not sure if that is the case. |
02-10-2015, 02:44 PM | #2 |
1144
Rep 892
Drives: None atm
For me it was due to the weather here in Sweden causing a lot of issues, The first time it happened i topped the liquid in the container, The Used a lot of the liquid on the windshield and it reseted it self somehow and the warning dint appear for a while, Then came a couple of weeks with -6-9c during night time and then during daytime it was around 4-8c so it freaked out again. Then i had it replaced.
02-10-2015, 03:07 PM | #3 |
48
Rep 108
What type of washer fluid are you using? Don't know how BMW does it but some of the VW folks have had issues with certain brands (RainX?) messing up the level sensor.
02-10-2015, 05:04 PM | #4 |
10
Rep 93
Had the same problem a few days ago. Thought that the fluid was frozen and the alarm came on. I am using -40C fluid. Senor issue maybe or crappy software ???
02-10-2015, 10:28 PM | #6 |
What goes here?
452
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
I had this issue just yesterday.... I too am using rainX fluid. It came on for a few drive cycles and has not come back on.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
02-11-2015, 08:25 AM | #8 |
72
Rep 177
02-11-2015, 12:06 PM | #9 |
76
Rep 389
Well, I noticed something, the light was coming on during really cold temps in my area.
When used the washer, I noticed my headlight washer never came on. Maybe due to temps? Then a couple of days ago when it got warmer around upper 30's. The headlight was sprayed. Every since then, the light haven't come on. |
02-11-2015, 12:15 PM | #10 |
What goes here?
452
Rep 1,356
yeah.. I don't have time to drive to the dealer to get my windshield wiper fluid refilled.
2019 G30 M550i
03-01-2015, 06:24 PM | #12 |
39
Rep 106
The washer fluid level sensor is a capacitive sensor with contactless measurement through two small lances. The sensor is part of the washer fluid tank. RainX washer fluid is known to damage this sensor which will require its replacement.
Just us the cheap blue washer fluid you can get at the gas station and it shouldn't be a problem. |
03-04-2015, 09:40 PM | #13 | |
76
Rep 389
Yes, you are correct, I did end up putting in the cheap blue washer and the light did go away. |
