Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 325D high pitched humming
      02-09-2015, 07:40 AM   #1
smithy79
Drives: E92 325d M Sport Coupe
Hi
Last week my car started to produce a high pitched humming noise from what seems to be around the back right of the car. It is a constant humming, and does not change in speeds and it there at idle? I cant see any change in the cars performance?
Does anyone have any ideas, before i get it checked.
Thanks
Mark
      02-09-2015, 08:02 AM   #2
Phil325i
Phil325i's Avatar
616
Drives: E92 325i MSport Coupe
The facts it's there when the car is at rest rules out all the usual suspects like tyres, wheel bearings, seized calipers etc. Only source of a noise like that at the rest I know of is the low pressure fuel pump. I think you need to get the car up on a ramp and have a listen...
EDIT - just realised you have a diesel. Not so sure what the fuel pumping arrangements are on the diesel. On petrol cars there is a two-stage process - low pressure pumping from the rear and a high pressure pump in the engine bay.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      02-09-2015, 12:15 PM   #3
kiel_dafo_kenyg_as
DIE ANTWOORD
Germany
68
Drives: 335d E92
You may have a vacuum in the tank. When the humming is back pull the tank cap and see if it stops.
King of the road says you move to slow
http://www.e90post.com/forums/album.php?albumid=11471&pictureid=55607
      02-09-2015, 03:20 PM   #4
Oneeb
Oneeb's Avatar
Drives: BMW 330d
I had a constant high pitched whining type noise coming from the right back, turned out to be the fuel filter.
Previous owner didn't change it when it got serviced and so it was getting blocked.
