BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > White smoke 330d 08
      02-02-2015, 10:58 AM   #1
ctunnicliffe01
ctunnicliffe01's Avatar
Drives: Bmw 330d
White smoke 330d 08
I've noticed recently in this lovely cold climate we are having that my 330d seems to be smoking white more than usual.
Only seems to do it from cold. Once warm it settles down fine.
When cold under acceleration it seems to give of a nice cloud. Only issue is i'm not Mr Bond escaping the rozzers.
but do the same once warm and no issues ...
oil is good. oil cap is good. no rough running. pulls fine. drives fine.
could this be egr cooler issues?
answers on a postcard please
(just thinking with short journeys heating the engine and cooling could i just be causing bad condensation or am i just hoping haha)
      02-02-2015, 02:23 PM   #2
HighlandPete
6659
Drives: BMW F11 535i Touring
Almost certainly condensation. White smoke from a diesel is most unusual, typically poor combustion in sub zero start ups, plus it is acrid smelling and lingers.
My car will put out condensation even after a 12 mile return trip, in the present freezing conditions. Cold temperatures, humidity and dew point all work together to make lots of the stuff.
As long as you are not losing coolant, I'd say it is normal winter condensation.
HighlandPete
      02-03-2015, 03:44 AM   #3
dy63
162
Drives: F30
check injector
      02-03-2015, 03:53 AM   #4
ctunnicliffe01
Drives: Bmw 330d
can i add i do have a small amount of coolant going missing . had to top up around 4 weeks ago. but cannot find leak anywhere. hence i may change egr cooler ...
going to disconnect it later to see if its sooty or full of coolant ... !! nice day for it... lol
      02-03-2015, 01:56 PM   #5
ctunnicliffe01
Drives: Bmw 330d
Replaced egr cooler . had coolant in it .
Not sooty just sludgey. Other end was steam cleaned .
Replaced it and just waiting for tomorrow to make sure system has bled ok . 😂😂😂
      02-05-2015, 06:48 AM   #6
sal_park
sal_park's Avatar
Drives: 2008 E91 325i manual
Humm, that's interesting - I've got an 08 325i but have exactly the same symptoms - some white smoke and using a very small amount of water, probably about 400ml in 15k miles. Obviously totally different engine (both direct injection though) but the symptoms are so similar.
      02-05-2015, 11:06 AM   #7
ctunnicliffe01
Drives: Bmw 330d
was deffo the egr cooler mate. the difference is massive now on cold start.
not loosing coolant either. at one stage i was having to top up once a month .
car seems to be warming up quicker now and heater is warm quicker. all good.
id seriously think about checking the cooler if your getting white smoke
ill get a pic of the old cooler and what it looked like when removed. !
      02-05-2015, 02:42 PM   #8
elbutio
Drives: 335d F31 & 330d E91
Be very interested to see that PIC. Glass you've got it sorted
      02-06-2015, 10:24 AM   #9
ctunnicliffe01
Drives: Bmw 330d
As you see in the 3rd picture there is water/coolant where there should be dry and sooty.
Instead coolants been escaping and being exhausted as that lovely white steam from the exhaust.
And can confirm there was a big difference on my e90 330d following the changed cooler!!
