Do i need camber arms after upgrading to Coils?
01-30-2015, 12:05 PM | #1 |
26
Rep 168
Planning on order coils soon and I have some question concerning do I need to get camber arms for the rear since the car is going to be sitting lower?
01-30-2015, 03:08 PM | #2 |
56
Rep 1,464
Drives: 2009 BMW 335xi
Unless you go really low, probably not. Both my cars were able to be in spec or very close with moderate drops.
01-30-2015, 05:26 PM | #3 |
Supreme Allied Commander
3886
Rep 54,525
Drives: F80 M3
No, not likely.
If you go way low, you may need adjustable toe arms to get the camber within specs as OE toe arms tend to bind up at extreme low ride heights. |
01-30-2015, 05:29 PM | #4 |
26
Rep 168
I'm plan in on going fairly low but not slammed. I see that Megan Racing have Camber arms and toe arm. So toe arm would be the only thing I need?
01-30-2015, 05:39 PM | #5 | |
3886
Rep 54,525
Drives: F80 M3
Have a look at these too: http://www.hpashop.com/HP-Autosport-...?categoryId=-1 |
01-30-2015, 06:18 PM | #6 | ||
26
Rep 168
02-04-2015, 02:14 PM | #8 |
164
Rep 2,556
Those HPA RE toe arms get noisy and clunky real quick due to spherical rod ends. I gave mine away after 2 months of road use. Megan racing will serve better. I'd want to reduce that rear camber to under -2d for tread wear. TMS sells and eccentric bushing for the oe camber arms to adjust camber. MR also sells adjustable camber links.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
02-04-2015, 03:28 PM | #9 | |
1234
Rep 3,778
Drives: '11 328i '19 M6
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
