Oil Level Display Tricking Me...
01-28-2015, 01:16 AM | #1 |
13347
Rep 7,484
The devil is alive!
Last month... oil warning. Added 1 Liter. The dipstick displayed as max. after this. Last week... checked it and it displayed as OK. Earlier week... I am back on max. and yesterday it was on OK. Today I am one notch below the max. mark. Is this some kind of pre-warning of a faulty oil level sensor?? Easy to do job or add it to warranty? |
01-28-2015, 02:11 AM | #2 |
26
Rep 639
If you are checking the oil in different places the car might not exactly be level and giving a false reading. I have a 325i aswell and it drinks oil like a beast, atleast 1 litre a month (800-900miles). I thought i had a leak, it concerned me that i just had to get it checked out. The garage had it for a day and they couldn't find any leaks.
01-28-2015, 04:56 AM | #3 |
283
Rep 2,343
Sensor seems to be at the back of the engine nearest the driver. Nose points slightly uphill, level above true. Nose points a little downhill, level below true. Perfectly level. Sensor reads accurately. As that scale seems to be for 1 ltr it can vary quite alot. I crapped my pants first time I got the red warning on a hill. Then worried my sensor was failing being up and down so much. Bring back the dip stick!
01-28-2015, 06:17 AM | #4 | |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Oil_Sensor.pdf
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
01-28-2015, 05:47 PM | #5 | |
283
Rep 2,343
I'm sure you'd get the most accurate reading that way. If I want an accurate reading on mine I do it stationary on level ground waiting for the engine to warm up. |
01-29-2015, 02:38 AM | #6 |
26
Rep 639
+1
01-29-2015, 05:43 AM | #7 |
616
Rep 3,194
Yes it does...if you're checking the level while the vehicle is at a standstill. But it also says (and I quote) "You can have the oil level displayed while you are driving...".
And even at a standstill, the engine has to be running.
01-29-2015, 11:36 AM | #8 | |
Wheelbarrow Edition
60
Rep 1,608
Probably leaking internally of the engine. Valve stem seals or something |
01-29-2015, 01:42 PM | #9 |
283
Rep 2,796
If you can't se any visible leaks and the sensors fighting fit on a 325 you need to look at the following:
Rocker Cover Gasket Oil Filter Housung Leak(caused by a failing gasket) Vacuum Pump Leak Breather Valve/Breather Pipe Contamination(highly likely) If you can't see any leaks and no leaks are confirmed when inspected and you're losing/or seem to be using oil with no explanation the breather unit and contaminated pipes would be where I'd look as the 325/330 can use a litre of oil if these are done for within 400/500 miles we've seen plenty. As for the Micky mouse level sensor can be used static/on the move |
01-30-2015, 04:32 PM | #10 |
106
Rep 1,562
Going by what I have heard off the bmw geeks It doesn't matter what position the car is in as the oil level is calculated by how long it takes to get to a certain temp or something along them lines. So as we are having very cold temps at the mo it's messing the system up. My oil level has started playing up since it has got cold and I am seeing many other posts recently saying the same thing. I changed my sensor costing me £150 for the sensor and then Labour on top and mad sod all difference so get it in a warm garage or something and try checking it.
02-01-2015, 10:50 AM | #11 | |
13347
Rep 7,484
